Pascal Vittoz Posted November 16, 2010 Share Posted November 16, 2010 I need to use a curve truss as light position but this truss is not parallel to the stage floor, i need for example 20? from downstage to upstage. How can i do that ? because each time i try to rotate the light position, i get a message "hybrid object can rotate only on Z axis" Thanks Quote Link to comment
michaelk Posted November 16, 2010 Share Posted November 16, 2010 In the OIP check "Draw 3D only" This will allow you to rotate the truss in any direction. hth mk Quote Link to comment
Pascal Vittoz Posted November 16, 2010 Author Share Posted November 16, 2010 It works for the truss but not if i convert the truss in a light position Quote Link to comment
