Script wont run in symbol
I have written a script to change the lineweights of objects in a drawing based on there existing lineweight and it works fine in a layer but I can not get it to work in a symbol. Does anyone know what I could do to make this work. One Idea I have is to cut the objects out of the symbol and place them on a layer make the change and then put them back in the symbol but I do not know how do do this in a script.
my script is below.
Procedure Lineweight;
Label 100, 101, 102, 103, 104, 105, 106;
VAR
H1 : HANDLE;
P1,P2 : real;
Begin;
DSelectAll;
SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (LW=7));
DSelectObj(INSYMBOL & INVIEWPORT & (T=TEXT));
H1:= FSActLayer;
100:SetLW(H1,3);
H1:=NextSObj(H1);
if H1<>Nil then goto 100;
DSelectAll;
SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (LW=10));
H1:= FSActLayer;
101:SetLW(H1,4);
if H1<>Nil then goto 101;
DSelectAll;
SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (LW=14));
H1:= FSActLayer;
102:SetLW(H1,6);
H1:=NextSObj(H1);
if H1<>Nil then goto 102;
DSelectAll;
SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (LW=20));
H1:= FSActLayer;
103:SetLW(H1,8);
H1:=NextSObj(H1);
if H1<>Nil then goto 103;
DSelectAll;
SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (LW=28));
H1:= FSActLayer;
104:SetLW(H1,11);
H1:=NextSObj(H1);
if H1<>Nil then goto 104;
DSelectAll;
SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (LW=39));
H1:= FSActLayer;
105:SetLW(H1,12);
H1:=NextSObj(H1);
if H1<>Nil then goto 105;
End;
Run (Lineweight);
Since I did not need to keep the symbols as symbols I was able to convert them to groups and then my revised script worked for the entire drawing. Thanks for the input.
PROCEDURE SelectedObjLineWeight;
Var
cw:integer;
FUNCTION explodeob(h:HANDLE) :BOOLEAN;
BEGIN
SymbolToGroup(h,2);
END;
FUNCTION edObject(h:HANDLE) :BOOLEAN;
BEGIN
cw:=GetLW(h);
if cw = 1 then SetLW(h, 8);
if cw = 7 then SetLW(h, 4);
if cw = 10 then SetLW(h, 6);
if cw = 14 then SetLW(h, 8);
if cw = 20 then SetLW(h, 11);
if cw = 28 then SetLW(h, 12);
if cw = 39 then SetLW(h, 15);
END;
BEGIN
DSelectAll; SelectObj(INSYMBOL & INVIEWPORT & (T=Symbol));
ForEachObjectInLayer(explodeob, 2, 2,1);
ForEachObjectInLayer(edObject, 0, 2,1);
END;
Run(SelectedObjLineWeight);
