Bob-H
Purge Polys command
I recently verified that this script works in Vw 2011. It's open source and royalty free. It reduces the vertices of 2D polys.
Full script is below this line (do not include the lower signature line):
{$STRICT 8}
{$NAMES 8}
{______________________}
PROCEDURE SimplifyPolys;
{ Somewhat Smarter Poly Simplifier - Public Domain - JDW }
{ Off the top of my head so may be slow and/or stupid algorithm
and possibly quite buggy. User beware. VectorScript gurus
encouraged to spiff it up. At least one compiler bug found
resulting in a more peculiar script to get around it. }
{ Doesn't work on 3D polys (easy to add tho), doesn't handle
polylines with invisible edges nicely. }
{ Most of these routines assume that the poly handle and other
parameters are valid (outer routines check them for inner
routines). Be careful if modifying the code or extracting
pieces of it. }
CONST
debug = FALSE;
debugWait = FALSE;
VAR
objType : INTEGER;
h, hTemp : HANDLE;
tolerance : REAL;
str : STRING;
degenerate : BOOLEAN;
bogus : BOOLEAN;
numVerts : INTEGER;
PROCEDURE DoWait; BEGIN IF debug AND debugWait THEN Wait(1); END;
PROCEDURE RemoveDuplicateVertices2D;
{ Deletes if degenerate poly. Not sure it handles mixed vertex
types well, but don't care enough to think about it. }
VAR
i : INTEGER;
x, y, lastX, lastY : REAL;
BEGIN { RemoveDuplicateVertices2D }
IF debug THEN BEGIN Message('RemoveDuplicateVertices2D'); DoWait; END;
numVerts := GetVertNum(h);
IF numVerts > 1 THEN BEGIN
GetPolyPt(h, numVerts, lastX, lastY);
FOR i := numVerts - 1 DOWNTO 1 DO BEGIN
GetPolyPt(h, i, x, y);
IF (x = lastX) AND (y = lastY) THEN
DelVertex(h, i)
ELSE BEGIN
lastX := x;
lastY := y;
END;
END;
END;
{ final cleanup }
IF (numVerts < 2) OR
((numVerts = 2) AND (lastX = x) AND (lastY = y))
THEN
degenerate := TRUE;
END; { RemoveDuplicateVertices2D }
PROCEDURE SimplifyPoly2D;
PROCEDURE TryToRemovePointsBetween(startIndex, endIndex : INTEGER);
VAR
lineStart, lineEnd, lineDir : VECTOR;
i : INTEGER;
midIndex : INTEGER;
keepGoing : BOOLEAN;
numVertsRemoved, savedNumVerts, numVerts : INTEGER;
FUNCTION PointIsNearlyCollinear2D(index: INTEGER) : BOOLEAN;
{ Given a line going through lineStart in the direction of the
unit vector LineDir, determines if the vertex of the polygon h
is less than tolerance away from its projection on the line. }
VAR pt, ptOnLine : VECTOR;
BEGIN { PointIsNearlyCollinear2D }
IF debug THEN BEGIN
WriteLn('PointIsNearlyCollinear2D ', index);
Message('PointIsNearlyCollinear2D ', index);
DoWait;
END;
pt[3] := 0;
GetPolyPt(h, index, pt[1], pt[2]);
pt := pt - lineStart;
ptOnLine := DotProduct(pt, lineDir) * lineDir;
IF Norm(pt - ptOnLine) > tolerance THEN
PointIsNearlyCollinear2D := FALSE
ELSE
PointIsNearlyCollinear2D := TRUE;
END; { PointIsNearlyCollinear2D }
VW8.5 has a recursion bug which clobbers this; should be fixed in 9
Peculiarly doesn't affect other recursion in this file...
FUNCTION PointsAreNearlyCollinear2D(startIndex, endIndex : INTEGER)
: BOOLEAN;
VAR
midIndex, i, span : INTEGER;
collinear : BOOLEAN;
BEGIN { PointsAreNearlyCollinear2D
IF debug THEN BEGIN
WriteLn('PointsAreNearlyCollinear2D ', startIndex, ', ', endIndex);
Message('PointsAreNearlyCollinear2D ', startIndex, ', ', endIndex);
DoWait;
END;
span := endIndex - startIndex;
IF span < 4 THEN BEGIN
collinear := TRUE;
FOR i := startIndex TO endIndex DO
collinear := collinear AND PointIsNearlyCollinear2D(i);
PointsAreNearlyCollinear2D := collinear;
END
ELSE BEGIN
{ this might fail for large polys.... XXX
midIndex := (endIndex + startIndex) / 2;
PointsAreNearlyCollinear2D := (
PointsAreNearlyCollinear2D(midIndex, endIndex) AND
PointsAreNearlyCollinear2D(startIndex, midIndex - 1)
END;
END; { PointsAreNearlyCollinear2D
FUNCTION WorkaroundPointsAreNearlyCollinear2D(startIndex, endIndex : INTEGER)
: BOOLEAN;
VAR
stack : ARRAY[1..32000, 1..2] OF INTEGER; { 32k absurdly more than needed! XXX }
i, j, midIndex, span : INTEGER;
long : LONGINT;
collinear, keepGoing : BOOLEAN;
BEGIN { WorkaroundPointsAreNearlyCollinear2D }
IF debug THEN BEGIN
WriteLn('WorkaroundPointsAreNearlyCollinear2D ', startIndex, ', ', endIndex);
Message('WorkaroundPointsAreNearlyCollinear2D ', startIndex, ', ', endIndex);
DoWait;
END;
i := 1;
stack[1,1] := startIndex;
stack[1,2] := endIndex;
collinear := TRUE;
WHILE (i > 0) AND collinear DO BEGIN
IF debug THEN BEGIN
WriteLn('Stack level: ', i, ' ');
Message('Stack level: ', i, ' ');
DoWait;
END;
span := stack[i,2] - stack[i,1];
FOR j := stack[i,1] TO stack[i,2] DO
collinear := collinear AND PointIsNearlyCollinear2D(j);
i := i - 1;
IF debug THEN BEGIN
WriteLn('Down to level: ', i, ' ');
Message('Down to level: ', i, ' ');
DoWait;
END;
{ compiler bug? gives array out of bounds index; or did before, maybe that was my bug...
WHILE (i > 0) AND (stack[i,1] = -1) DO BEGIN
i := i - 1;
IF debug THEN BEGIN
DoWait;
END;
END;
keepGoing := TRUE;
WHILE (i > 0) AND keepGoing DO BEGIN
IF stack[i,1] <> -1 THEN
keepGoing := FALSE
ELSE BEGIN
i := i - 1;
IF debug THEN BEGIN
DoWait;
END;
END;
END;
END
ELSE BEGIN
long := stack[i,1]; { avoid short int overflow for huge polys }
midIndex := (long + stack[i,2]) / 2;
IF debug THEN BEGIN
WriteLn(i+1, ': ', stack[i,1], '-', midIndex - 1, ' ',
i+2, ': ', midIndex, '-', stack[i,2]);
Message(i+1, ': ', stack[i,1], '-', midIndex - 1, ' ',
DoWait;
DoWait;
DoWait;
END;
stack[i+1,1] := stack[i,1];
stack[i+1,2] := midIndex - 1;
stack[i+2,1] := midIndex;
stack[i+2,2] := stack[i,2];
stack[i,1] := -1;
i := i + 2;
END;
END;
WorkaroundPointsAreNearlyCollinear2D := collinear;
END; {WorkaroundPointsAreNearlyCollinear2D }
BEGIN { TryToRemovePointsBetween }
IF debug THEN BEGIN
WriteLn('TryToRemovePointsBetween ', startIndex, ', ', endIndex);
Message('TryToRemovePointsBetween ', startIndex, ', ', endIndex);
IF endIndex > GetVertNum(h) THEN BEGIN
WriteLn('INDEX OUT OF RANGE! ', endIndex, ' > ', GetVertNum(h));
Message('INDEX OUT OF RANGE! ', endIndex, ' > ', GetVertNum(h));
END;
DoWait;
END;
lineStart[3] := 0;
lineDir[3] := 0;
GetPolyPt(h, startIndex, lineStart[1], lineStart[2]);
keepGoing := TRUE;
WHILE (endIndex - startIndex > 1) AND keepGoing DO BEGIN
GetPolyPt(h, endIndex, lineEnd[1], lineEnd[2]);
{IF (lineEnd = lineStart) THEN BEGIN - compiler bug ? fails periodically}
IF (lineEnd[1] = lineStart[1]) AND (lineEnd[2] = lineStart[2]) THEN BEGIN
IF debug THEN BEGIN
WriteLn('Skipping zero length segment; i = ', endIndex);
Message('Skipping zero length segment; i = ', endIndex);
DoWait;
END;
endIndex := endIndex - 1;
END
ELSE BEGIN
keepGoing := FALSE;
IF debug THEN BEGIN
WriteLn('keepGoing := FALSE');
Message('keepGoing := FALSE');
DoWait;
END;
END
END;
IF (endIndex - startIndex > 1) THEN BEGIN
lineDir := UnitVec(lineEnd - lineStart);
IF WorkaroundPointsAreNearlyCollinear2D(startIndex, endIndex) THEN BEGIN
FOR i := endIndex - 1 DOWNTO startIndex + 1 DO BEGIN
IF debug THEN BEGIN
WriteLn('Deleting ', i);
Message('Deleting ', i);
DoWait;
END;
DelVertex(h, i);
END
END
ELSE IF (endIndex - startIndex > 2) THEN BEGIN
IF debug THEN BEGIN WriteLn('Right'); Message('Right'); DoWait; END;
{ this might fail for large polys.... XXX }
{ a bit inefficient for small spans but whatever }
TryToRemovePointsBetween(midIndex, endIndex);
IF debug THEN BEGIN WriteLn('Left'); Message('Left'); DoWait; END;
savedNumVerts := GetVertNum(h);
TryToRemovePointsBetween(startIndex, midIndex);
IF debug THEN BEGIN WriteLn('Mid'); Message('Mid'); DoWait; END;
numVertsRemoved := savedNumVerts - numVerts;
midIndex := midIndex - numVertsRemoved;
IF (midIndex > 1) AND (midIndex < numVerts) THEN BEGIN
TryToRemovePointsBetween(midIndex - 1, midIndex + 1);
END;
END;
END;
END; { TryToRemovePointsBetween }
BEGIN { SimplifyPoly2D }
IF debug THEN BEGIN Message('SimplifyPoly2D'); DoWait; END;
RemoveDuplicateVertices;
IF NOT degenerate THEN BEGIN
TryToRemovePointsBetween(1, GetVertNum(h));
END;
END; { SimplifyPoly2D }
BEGIN { SimplifyPolys }
IF debug THEN BEGIN Message('SimplifyPolys'); DoWait; END;
h := FSActLayer;
str := Num2StrF(0.1);
tolerance := DistDialog('Maximum deviation from poly:', str);
bogus := FALSE;
WHILE (h <> NIL) AND (NOT bogus) DO BEGIN
degenerate := FALSE;
objType := GetType(h);
CASE objType OF
0: BEGIN
IF debug THEN BEGIN
Message('Term Node!');
DoWait;
SysBeep;
END;
bogus := TRUE;
END;
5, 8, 21: { polygon, freehand polygon, polyline }
SimplifyPoly2D;
END;
hTemp := h;
h := NextSObj(h);
IF degenerate THEN BEGIN
DelObject(hTemp);
{ should give user alert that poly was deleted...
but only once }
END;
END;
END; { SimplifyPolys }
RUN(SimplifyPolys);
Edited by Bob-H
I don't have any experience with scripts. I did name and save the script into Tools/Scripts/PlugIn Editor.
Then imported an image of a floor plan, selected it, and then went to Scripts/Run Script. A window opens for selecting the file. It's not to be found.
In the Resources Browser, there seem to be no scripts available.
It would help to know how to invoke the script, in what context, and what to expect. Thanks.
