grant_PD Posted August 20, 2010 Share Posted August 20, 2010 Is there any way to have a symbol that numbers itself as you place instances in the layer? ie. I place 4 chairs in the layer, the instances number themselves 1,2,3,4 on the 2d portion. I place 4 more, they number themselves 5,6,7,8. Take away two and they reassign themselves. Sounds complicated as I write it.... Quote Link to comment
Guest Mark Flamer Posted August 20, 2010 Share Posted August 20, 2010 If you use a tool based PIO, it can number the objects as they are placed. Having them renumber themselves is much more complicated, but can be done. Look for info on "ResetObject" at the developer website. It has a pretty good article on linking objects. Quote Link to comment
maarten. Posted August 21, 2010 Share Posted August 21, 2010 (edited) If you want to use symbols: To place them could this be a way: The name of the symbol in this example is Chair. There's a record with the name RName and a field FName in the drawing. A text object in the symbol is linked to that record field. PROCEDURE Voorbeeld; {This is a menu commando or a document script} {This is just a sketch, not fully tested} VAR crit : STRING; aant,tel : INTEGER; x,y : REAL; b : BOOLEAN; BEGIN {count the number of already placed chairs on this layer} crit:=ConCat(Chr(40),Chr(40),'S=',Chr(39),'Chair',Chr(39),Chr(41),Chr(38),Chr(40),'L=',Chr(39),GetLName(ActLayer),Chr(39),Chr(41),Chr(41)); aant:=Count(crit); {start a loop until the user selects a tool or presses esc} REPEAT {let the user click and place there the symbol} GetPt(x,y); Symbol('Chair',x,y,0); {set the number} tel:=tel+1; SetRField(LNewObj,'RName','FName',Num2StrF(aant+tel)); {redraw the screen to show the symbol} Redraw; UNTIL(b); END; RUN(Voorbeeld); A script can not be run when you delete an object, so you still have to run it manually every time you delete a chair. How do you want them to be renumbered? The first placed will always have nr1, the second nr2,... and the last placed nrX? If so, it isn't that hard because you can use the order that VS uses. When VS does a search through the objects, it starts with the first created and ends with the last created. PROCEDURE ReNumber; {This is a menu commando or a document script} {This is just a sketch, not fully tested} VAR crit : STRING; tel : INTEGER; PROCEDURE SetNumber(h : HANDLE); BEGIN tel:=tel+1; SetRField(h,'RName','FName',Num2StrF(tel)); END; BEGIN crit:=ConCat(Chr(40),Chr(40),'S=',Chr(39),'Chair',Chr(39),Chr(41),Chr(38),Chr(40),'L=',Chr(39),GetLName(ActLayer),Chr(39),Chr(41),Chr(41)); ForEachObject(SetNumber,crit); Redraw; END; RUN(ReNumber); If you want an other way to renumber them, you'll have to figure out how you want to do them so we can see if it's possible in VS. Edited August 22, 2010 by maarten. Quote Link to comment
