MakePolygon not working for groups
Hi,
I want to find what objects are within a 2D polygon region.
Currently I pick a polygon and duplicate it with h2=MakePolygon(h) then name it with SetName(h2,'tmp').
After this I will:
ForEachObject (Check_for_X,((Loc = 'Tmp') & (T = X)));
if (h2 <> Nil) then DelObject(h2);
This works well but when I have two polygons grouped that represent the final product I can't use MakePolygon.
Any suggestions on how to create a tmp polygon profiling the perimeter of the final product?
Hi Who,
You can get the handle of the 1st object in a group with:
???h2a := FinGroup(GrpHand);
and get a handle to the next object in the group with:
???h2b := NextObj(h2a);
If they happen to be Polys, so much the better.
OR, you can duplicate the group with:
???Grouplic8Hand := hDuplicate(GrpHand, 0, 0);
OR, move pieces into a Group with:
???boo := SetParent(h2, GrpHand);
or out of a Group with:
???boo := SetParent(h2, GetParent(GrpHand));
If you want to merge the two polys in your group into one (assuming they overlap), you might use:
???h3 := AddSurface(h2a, h2b);
and then ungroup it with:
???hUngroup(GrpHand);
I'm not sure which approach, if any, would work for you. I'll let you pick.
Have fun,
Raymond
