FEA-IT
Staircase disappearing
I'm using VW2008 at work and trying to put in two staircases using the tool into a building. Both stairs go from ground to first floor. I worked out to set the Z level of the plan layers and linked the stairs to both the layers. I create the first staircase and it is created on the ground floor and first floor correctly. I then create the second set of stairs and they appear on the ground and first but the initial first set of stairs disappears from the first floor. If I open the settings for the first staircas and click ok it reappears but the second disappears. Why can't I have 2 sets of stairs?
Edited by FEA-IT
If I remember correctly there is a bug in VW2008 that incorrectly links stairs when using the layer height option.
Check out these threads:
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=101890
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=97085
Also, make sure you have the latest release of VW2008. I think it is Service Pack 3.
Updated to SP3 and deleted then re-created the stairs and they seem to be working now. Thanks for the help!
