JSiegel Posted May 10, 2010 Share Posted May 10, 2010 Hi All, Now that I have a well built model. What is the best way to present the elevations as CD's. Is the preferred methodology to: 1.) copy the "elevation viewport" as a hidden line rendering/convert to group & then cleaning up lines as necessary 2.) then overlay that hidden line drawing over the original FQRW rendering in the SLVP 3.) then annotating the elevations in the SLVP Just looking for some insight on best practices. See attached screen shot. TY Jeremy Quote Link to comment
CipesDesign Posted May 10, 2010 Share Posted May 10, 2010 Jeremy, try this: create a viewport for each side of the building. Use FQRW for the Background Rendering and Hidden Line for the Foreground. This in itself might give you what you want. If you find a lot of incorrect line work then you may need to do the convert to group procedure and clean up the lines, etc... P Quote Link to comment
JSiegel Posted May 10, 2010 Author Share Posted May 10, 2010 Peter, What you are describing is what I had done for the screen shot which I will need to clean up. I will use convert to group as you mention. TY Jeremy Quote Link to comment
