Yoginathaswami
Customizing View Bar
Aloha, I am wondering if the view bar items can be moved around. All the Mac OS applications allow the users to customize the view bar i.e. add and remove things and move them around the bar. I wish VW will allow this. Thanks
4 answers to this question
Hi?Yoginatha, again you need to edit the Workspace to sort things as you want.
Select "Edit Workspace" and in the screen that pops up the left panel is how things are with all it's present contents . . . . Rearange them to your requirements.
Waning! Don't go mad, or you'll end up loosing things, unless you keep a note on where you put them.
Sorry, forgot. The right hand panel contains EVERYTHING available to VW. When you install/add Plug-Ins this is where you'll find them hidden. Once found and selected you drag it from the right panel to the left panel. You can create new Menus here too, specifically for personal favorites. But like I said before, don't go mad.
Add new components 1 or 2 at a time to see how they work for you.
Mind you, you can always go back to the default if it doesn't work out for you.
BTW, modify a copy of the default so you've something to revert too.
Hi AndiACD, yes I am aware of the menu customization. However, I am looking for a way to change view bar. See the attached image if that make sense. If there is away to do it, that will be wonderful. Thank you again for your help!
Yeah, that might be more of a mountain than a molehill. I think that Tomu might be the man to talk to as I think this is a case of editing the file itself directly. Not exactly highly recomended.
