sancho1981 Posted December 30, 2009 Share Posted December 30, 2009 Is there a good way to create lighting sections in VW2009? Right now I have been trying to create a viewport on a new sheet layer with a side view of the 3-d set, but I can only get it in wireframe. I would like to build a set in 3-d space, switch to side view and draw my beam spreads and sightlines. Is this a pipedream? Thanks for your help. Quote Link to comment
michaelk Posted December 30, 2009 Share Posted December 30, 2009 Not a pipe dream at all. VW does this really well. one way: 1. in a design layer, plan view. View>Create Section Viewport...> draw the section line ( indicate which way to "look")> Pick a sheet layer. 2. in the resulting section viewport's OIP set background render to hidden line or open GL or ... another way: 1. Create a viewport w/ the appropriate layers and classes on a sheet layer. 2. Select the viewport View>Create Section Viewport...> draw the section line ( indicate which way to "look") you get the idea... either way: once you have the section viewport, double click it, choose annotations and draw your beams and sight lines. hth michaelk Quote Link to comment
sancho1981 Posted December 30, 2009 Author Share Posted December 30, 2009 Booyah! I knew I would love this program. Many thanks! Shawn Quote Link to comment
