Design Layer Viewport Boundary Issues
Gytis
I'm having trouble with the boundary indicated by selection/pre-selection for DLVPs. Specifically, it is much larger than expected--making it hard to work with the DLVPs because of all sorts of overlapping.
I have spent some time trouble-shooting, i.e. looking for "hidden" objects like lights, dimensions, or loci which might create the unexpected results. The bottom line is that for a particular design layer, even when ALL classes are turned off, the boundary is still large and unexpected.
IF I change to another design layer (still leaving all classes off) THEN the boundary changes to the expected: minimal, microscopic dot.
IF I navigate to the design layer from the DLVP and Select All, there is nothing.
IF I delete all other objects on the design layer, all is good!
Any ideas or experiences why or how a mysterious object does not respond to class control for a DLVP?
Screenshots:
why DLVP, why not make this object a symbol?
Long story here.
Short-ish version:
  • I use the DLVPs to keep file size manageable and efficient. 3D model in one file, unit-level shop drawings in another (or three).
  • I use DLVPs to populate a template Sheet Layer with multiple view Viewports. If straight from the model the VP objects are all over the place.
  • A symbol requires an additional click for editing and additional management time (name, insertion, location, etc.) Already a PIO....
is this an interiorcad object?
It is indeed.
I think I've made progress on the original issue. I bit by bit deleted objects until I isolated the offending animal. I'm pretty sure it is the light objects which stretched the DLVP boundary. Even in their own class, turned off!!??
Will report back with hard facts--and file bug report if in fact readily reproducible.
