VincentCuclair Posted September 16, 2009 Share Posted September 16, 2009 Anyone know if doors and windows retain parametric info in exported IFC? Quote Link to comment
Jeffrey W Ouellette Posted September 16, 2009 Share Posted September 16, 2009 No. Or, I should say, not directly. The current IFC export implementation does not make a "parametric" object. It exports the geometry of the object as a surface model with the appropriate data. It is the burden of the importing application to read the data describing the door/window and map the information, and geometry, to the desired native application parameters for that particular object. Quote Link to comment
VincentCuclair Posted September 17, 2009 Author Share Posted September 17, 2009 (edited) OK thanks Jeffrey, I'll check with Graphisoft if ArchiCAD 13 imports and converts this data yet...... if it does I can start drafting in VW 100% and leave ArchiCAD (everybody else at my office use ArchiCAD, however not it's 3D capabilities, they're still stuck at the AutoCAD Point level....so being able to import walls, doors and windows from VW would do the trick ) Edited September 17, 2009 by Vincent C Quote Link to comment
