Grant Williams Posted September 4, 2009 Share Posted September 4, 2009 For some reason I can not click on an arc and select, I can only select from the midpoint. This just started and I can't figure out what setting I need to change. Help Please. Thanks Quote Link to comment
michaelk Posted September 4, 2009 Share Posted September 4, 2009 Not quite sure what you mean... When you say you can't select it, do you mean 1- when you click on it the OIP doesn't say Arc in the top left corner? or 2- when you click on it you don't get the blue handles to modify it? If 1, then it may be a class or layer option setting. If 2, then the 2D selection mode is set to Disable Interactive Scaling Mode. With the 2D selection tool active click on the second mode button (below the Class pulldown). It looks like a diagonal arrow pointing down/left and up/right. hth michaelk Quote Link to comment
Ray Libby Posted September 7, 2009 Share Posted September 7, 2009 Grant, please create a signature with your version of Vectorworks including updates and computer specs including OS. Click on the My Stuff link at the top, Edit Profile. Quote Link to comment
