Steve Barrett Posted July 29, 2009 Share Posted July 29, 2009 Recently I've started having an issue with a chair model displaying correctly when using hidden-line mode. The model is very simple (the legs are just 3d polygon lines) as I sometimes need 16,000 or more of them in my drawings. When I render the legs and the back supports disappear. I started playing with the smoothing angle setting and if I set it to zero, the problem goes away. The issue with this setting is my curved trusses take on a faceted look which requires a smoothing angle of 10 or more. Any ideas or suggestions? Steve B. Quote Link to comment
Steve Barrett Posted July 29, 2009 Author Share Posted July 29, 2009 I had the wrong info on my previous signature Quote Link to comment
michaelk Posted July 29, 2009 Share Posted July 29, 2009 I don't know why this works, but it does. Add a vertex to the legs. It seems go off the deep end when you render a colinear 3D poly in hidden line with a smoothing angle. But as soon as the leg is non-colinear, it works fine. Maybe somebody out there will know why. hth michaelk Quote Link to comment
Steve Barrett Posted July 29, 2009 Author Share Posted July 29, 2009 Well this is odd. I added a vertex to the legs and support and when I render I get 1 leg only. Quote Link to comment
michaelk Posted July 31, 2009 Share Posted July 31, 2009 Again, I have no idea why this works. But all you need to do is add a little bend at one end of the leg or back support. It works. Don't know why. hth michaelk Quote Link to comment
