vhector Posted May 7, 2009 Share Posted May 7, 2009 Is there a way to export the drawing or maybe only vieport as "what you see is what you get". In vectorworks we always work solids and line in front or in back of each other. So like for example if you export a drawing and the part of a line behind a solid isn't exported with it. Save a lot of work for the other party who works with that dwg file. Quote Link to comment
Pat Stanford Posted May 7, 2009 Share Posted May 7, 2009 Check out Viewport to Design Layers This will get you the data from the viewport back to a design layer. From there you should be able to either create another viewport and export from there, or just set the other design layers to invisible and export the model space directly. Quote Link to comment
vhector Posted May 11, 2009 Author Share Posted May 11, 2009 The export to polygon was the first thing I tried, but everything disappears. I think this only works with 3d stuff. Quote Link to comment
