digital terrain modeling
A few things you may want to check:
Did your 3-d polys all have the correct z value after running 2-d contours to 3-d polys? Check by selecting 3-d polys and looking at the z value in the info palette. Also check to see if the range of z values match the range shown in the settings dialog box. If not you may need to change the scale of your 2d poly layer to more closely match the map you are tracing the contours from.
Do any of your 2-d contours cross? Run the DTM/check 3-d polys menu command to make sure.
Are some of the 3-d polys too close together? Run the filter 3d polygons tool to check.
These are a few things I check if a DTM does not work.
[This message has been edited by Marc Pitman (edited 04-01-2001).]
