jchan Posted October 13, 2008 Share Posted October 13, 2008 hi all, I have a problem to export the worksheet, I have drawn a window schedule with all the window symbols and attached a window schedule report in a sheet layer. when I checked the exported file, I noticed the worksheet become a blank polygon with white fill, anyone have this problem? and is it any method to bring it back? thanks, Quote Link to comment
Pat Stanford Posted October 13, 2008 Share Posted October 13, 2008 Worksheets are not exported to DWG/DXF in VW12. That support was added in VW2008. You either need to upgrade to a newer version of VW or check out Julian Carr's Worksheet on Drawing add-in. http://www.ozcad.com.au/otherproducts/vwaddonsWSOD.html Pat Quote Link to comment
jchan Posted October 13, 2008 Author Share Posted October 13, 2008 Thx Pat, then I don't need to spend more time on research, should save money to upgrade Quote Link to comment
