dovermyer Posted October 9, 2008 Share Posted October 9, 2008 Hi folks, I created a curved staircase in AutoCAD with regular solids. The stringers & handrails are sweeps along helices. When I try to open the file (as either dxf or dwg) in VW, it loads the treads & other simple solids, but it seems to completely ignore the objects swept along a helix. I'm using AutoCAD Architecture 2009 SP1 & VectorWorks Fundamentals 2008 SP3. I even tried to explode the helical objects into surfaces, but that didn't work either. I just need to import it so my colleague can include the staircase in his VW pretty-picture. Thanks in advance! Quote Link to comment
dovermyer Posted October 10, 2008 Author Share Posted October 10, 2008 Anyone have any advice?... Quote Link to comment
Ray Libby Posted October 10, 2008 Share Posted October 10, 2008 Maybe it's in a class that's not visible. Quote Link to comment
rDesign Posted October 11, 2008 Share Posted October 11, 2008 Maybe there's something in the DWG / DXF translation that is getting lost on import. Try exporting just the swept helix to 3DS or SAT format. Quote Link to comment
M.CH Posted October 11, 2008 Share Posted October 11, 2008 I'm using AutoCAD Architecture 2009 SP1 & VectorWorks Fundamentals 2008 SP3. Vw 2008 does not import Acad 2009, so you need the Acad file saved to an earlier version Quote Link to comment
dovermyer Posted October 13, 2008 Author Share Posted October 13, 2008 Maybe there's something in the DWG / DXF translation that is getting lost on import. Try exporting just the swept helix to 3DS or SAT format. Thanks for your suggestion. However, it achieved the same results as the DXF. Vw 2008 does not import Acad 2009, so you need the Acad file saved to an earlier version. I always save to v2004. I even tried exporting to a R12 DXF. Nothing works...which leads me to believe that VW doesn't understand an ACAD helical sweep. Anyone else have suggestions, ideas, or thoughts on the matter? Quote Link to comment
dovermyer Posted October 14, 2008 Author Share Posted October 14, 2008 I'm going to assume that general silence here indicates that I'm trying something weird Quote Link to comment
rDesign Posted October 15, 2008 Share Posted October 15, 2008 You should probably contact NNA Tech support and see if they have any suggestions: NNA Tech Support Request Tim Quote Link to comment
