iBagwan Posted October 2, 2008 Share Posted October 2, 2008 Callouts generate a reference list that is vertical. Is there any way to get the notes to break up so you could put them in blocks horizontally? For instance, notes 1 thru 16 then a move to the right and notes 17 thru 30. Sometimes a drawing takes up most of the horizontal portion of the sheet so notes have to go below and run horizontal. A second question is, can you have more then one set of notes on a sheet? Sometimes I'll have multiple plans on a sheet and I like the reference notes to have a different start number to differentiate between the notes for each plan. I'm fairly new at this so I'm still stumbling around in the dark! Quote Link to comment
Jonathan Pickup Posted October 2, 2008 Share Posted October 2, 2008 you could use viewports to do this. one viewport could show 1-16, the second viewport from 16-32... Quote Link to comment
