I received a DWG file from someone. I imported the file and chose "Map Colors to Lineweights" I had the CTB file so everything imported correctly. The only problem I have is that all the lines are still colored. I would think this would be ok in autoCAD, but this is vectorworks. Do I need to manually change all the colors back to black? I would choose the easy method and check "Black and White Only" in the preference box but I need to do my work in Red and print it.
So is my only option to manually change the colors back to black after import?
MaxStudio
2 answers to this question
