XOP15 Posted September 8, 2008 Share Posted September 8, 2008 Hi There, Can anyone tell me a way to rotate a truss circle. I create the truss circle in plan view, I want to be able to rotate the circle 90? so that I can see the circle in front view. I did follow another thread that says to convert to lighting instrument, I select the circle, go to MODIFY, then go to CONVERT, I click on CONVERT TO INSTRUMENT, but it then get the message "only symbols can be converted to instruments. non symbols were not converted and have been selected" any ideas ??? Quote Link to comment
M.CH Posted September 8, 2008 Share Posted September 8, 2008 Create it as a symbol, select that symbol, select convert to instrument, then select check box Set 3D orientation and then select 90 x and 90 y and there you have it HTH Quote Link to comment
XOP15 Posted September 8, 2008 Author Share Posted September 8, 2008 HI MCH Thanks for your reply, i seem to be doing exactly what you are saying but i still get the message "only symbols can be converted to instruments. non symbols were not converted and have been selected" I am using the curved truss tool to create the circle. does this mean that i am not creating a symbol using the "curved truss tool" fairly new to Vectorworks so forgive my ignorance Running VW2008 Spotlight & renderworks, Many thanks once again. Quote Link to comment
BHunter Posted September 9, 2008 Share Posted September 9, 2008 (edited) Assuming that 2008 is reasonably close to 12.5, I can offer: draw your circle, look in the object info window, scroll down and check "draw 3D only", switch to side view, right click on circle, rotate, set your rotation angle. You should be good to go. In your case, you want 90 degrees, so Cntl L will flip it 90 degrees. Bob Hunter 315 Design Solutions Atlanta, Ga Edited September 9, 2008 by BHunter Quote Link to comment
XOP15 Posted September 9, 2008 Author Share Posted September 9, 2008 Hi Bob, Thats cracked it! perfect. Its doing exactly what I want it to do now. Many Thanks Bob. Best Regards, Dave. Quote Link to comment
M.CH Posted September 9, 2008 Share Posted September 9, 2008 You need to create a symbol of the truss, which means you then have an object you can use as a standard object. Bob's solution is also good if you are only using it once, but it is still available for copying and pasting Quote Link to comment
BHunter Posted September 11, 2008 Share Posted September 11, 2008 (edited) Anytime. No Worries Bob Edited September 11, 2008 by BHunter Quote Link to comment
