Disabling Auto-classing
I use an OZCAD add-on called "windoor13" so I don't use the standard window or door tool that comes with VW2008. On this one occasion I am using the garage door from VW2008 and I notice it creates 3 classes: "ceiling-main, non-plot and sills".
I don't want these in my job so I selected and deleted those classes. As soon as I select the door again the classes are recreated, which make sense.
I know that some objects that come with VW have "auto-classing" so I looked in the help menu for that topic.
This is what it says:
To set the standard naming of layers, classes, and views:
1. Select File > Document Settings > Standard Naming.
The Standard Naming dialog box opens. Select a naming standard for the file, and choose whether auto-classing should be enabled for objects.
There are 5 "active standards":
VWarch
VWarch simplified
AIA/NCS
User 1
User 2
User 3
I have selected each one and noticed that for all the tick box: "enable auto-classing" is unticked.
What do I do?
I don't know if this will help, I'd do it to a copy of the window PIO first. Go to the Vectorscript plugin editor
Go to Window > strings > misc. strings and hit edit. the classes are in there. I don't know what it will do if you change those, so proceed at your own risk.
