Record Modification
I have a simple question and am looking for opinions or suggestions on this matter.
I am in the process of updating a few hundred symbols with a few new record fields. What do you think would be the better way to go about this through VS.
I would like to also convert / update some older working files with the new record information also. Should I:
Just build a new record and run a script to add the new record information to the existing symbols from an updated symbol file that contains the new record information.
OR
Add the newer fields to the same record and then load the new information from an updated symbol file that contain the new record information.
Without attempting to do both I'm just wondering which method may be better.
Thanks in Advance
Jeff Miller
