Kvic Posted August 1, 2008 Share Posted August 1, 2008 More problems in paradise: My section viewport, derived from a DLVP has acquired arrow decease where by all my walls and windows have arrows as if they were lines. The SVP is comprised of annotations only ... the referenced file does not appear to have any over righting elements ...I need help Quote Link to comment
Kvic Posted August 1, 2008 Author Share Posted August 1, 2008 Has anyone experienced pdf files made through batch file where by there is nothing in some of the files only to find out after they have been printed for a permit submission date? Quote Link to comment
gmm18 Posted August 3, 2008 Share Posted August 3, 2008 Again, these questions are better suited for the General Discussion or VectorWorks Architect Forums. You won't get a good response if you keep posting this here. I am not sure about the SVP problem, as I don't understand what 'arrow decease' is. The Export Batch PDF has been a bit twitchy for me before, leaving a blank sheet in the PDF, but of course I checked the file before sending to the printer. All I had to do was run the Export again and it was fine. If you create a signature with your system specs that will also help for people to give you more focused advice. Quote Link to comment
