Kvic Posted August 1, 2008 Share Posted August 1, 2008 My main file which has a number of referenced files suffers from disappearing interior walls which are referenced from separate unit files as one zooms in and out on the sheet layer. At first I solved the problem when I noticed the rotation arrow was in the wrong position ...Cmd5... voila fixed but now it's doing it again. I've re-referenced and then edited and re-referenced (that worked before ) but I can't figure this thing out. My project is 3d, 3 building, 4 story w/ a multi-grade-parkade, 81 unit resort and I have a good deal of hours into this and cannot afford to loose it. It seems the larger and more complex the project get the harder it is for VW to manage. And this is just the first of many phase on this site. By the way I have the latest IMAC 24" and latest Build with VW2008 Help!?! mother!?! Quote Link to comment
gmm18 Posted August 3, 2008 Share Posted August 3, 2008 I think the key is to always save your referenced files in non-rotated Top/Plan view. Yes hit Command-5 before hitting Save. By the way, you should consider posting these sorts of questions under either the General Discussion or Architect Forum, since this is not a VectorScript issue. Quote Link to comment
