Andrew Mac Posted June 5, 2008 Share Posted June 5, 2008 When extruding polygons to say for example- 2" and thenget back to plan view- My polygon becomes transparent- Why is this happening- should the extruded polygon be a solid? Quote Link to comment
Ray Libby Posted June 5, 2008 Share Posted June 5, 2008 In this case the word solid is used two different ways. An extrude is a solid object, and an object can have a solid fill. Once you extrude you do have a solid object, but solid objects can't have a solid fill. If you need the object to have a fill in plan view, make a hybrid symbol, with the 2d portion having a fill. Quote Link to comment
M.CH Posted June 5, 2008 Share Posted June 5, 2008 Alternatively use the floor tool, then you have a hybrid object that can also be positioned in 3D space from the OIP, without having to make a symbol Quote Link to comment
