dramabear Posted May 19, 2008 Share Posted May 19, 2008 Does anyone know how to specify the placement of a container in a label legend? I know that I can grab the handle and move individual containers around but I want to uniformly change the default placement of some of my containers but have had no succes in being able to do this. Any suggestions? Quote Link to comment
Cris with no H Posted May 20, 2008 Share Posted May 20, 2008 A new label legend, perhaps? The center of the text is the center of its container. Quote Link to comment
dramabear Posted May 20, 2008 Author Share Posted May 20, 2008 THank you for the help- I have deduced that the container's center is over the center of the text but that's actually what I want to be able to adjust. I want to know how to be able to tell the container where I want it to be. Quote Link to comment
Albrecht Design Posted May 21, 2008 Share Posted May 21, 2008 (edited) Are you able to move the text of your label legend? Does the container move with it? Are you trying this on individual lights, or with a specific label legend through the label legend manager? I'm sorry if this is more info than you need, but here goes. To edit the label legend in 2008: Tools Label Legend Manager Select the label legend you want to edit Edit Layout move the text fields where you want them exit symbol you will need to refresh your instruments using that legend: Modify Refresh instruments Or, you will need to assign the legend again if refresh doesn't seem to work: Modify Assign legend to inst The text and the container should move to the new position you set. In earlier versions, the label legend manager is under a different menu: Spotlight Instrument Processing Label Legend Manager Assign legend and refresh instruments are also there. I hope this is what you are asking. Or are you asking if there is a way to change the relationship of the text and the container? Edited May 21, 2008 by Albrecht Design Quote Link to comment
dramabear Posted May 22, 2008 Author Share Posted May 22, 2008 Thank you and I apologize that you put all of those steps in for me but I have the set up of the label legends down it's your last statement: "...is there a way to change the relationship of the text and the container?" that I am wondering about. The only solution I've found to changing the relationship of the container and the text is by offsetting the container from 0,0 but that makes the container less useful for a wide range of label legends. Quote Link to comment
