SKR Posted May 12, 2008 Share Posted May 12, 2008 HI all is it possible to change the resolution of the model when I use QT object export option? Quote Link to comment
SKR Posted May 12, 2008 Author Share Posted May 12, 2008 I am trying to export a small model of a building component to Quicktime VR object. I can't find any option on the export dialoge box for setting the resolution. is there anyway to export this model at higher resolution? Quote Link to comment
islandmon Posted May 13, 2008 Share Posted May 13, 2008 As I recall ... QTVR uses the Display resolution based fundamentally on 72dpi. In order to resize the QTVR ... adjust the size of the VW screen to the size required for each of the movies. Then QTVR will utilize the VW page bounding box to determine the frame resolution based on the 72dpi. For increased resolution and larger file size just make the VW screen ( page ) larger. That's all there is to it ! Then when you use html tags you can set the frame size to maximize the viewing resolution ... ie: reduce frame by 50% doubles the resolution. Quote Link to comment
SKR Posted May 13, 2008 Author Share Posted May 13, 2008 Dear Islandmon many thanks for your tip. I will try to change the display resolution in VW preference and set the page size. will let you know how it goes. SKR Quote Link to comment
islandmon Posted May 13, 2008 Share Posted May 13, 2008 Clarification ... QTVR uses the VW "window" size. Set the size of the window to the size of the frame and let QT work it's magic. Quote Link to comment
