ErichR
Animation Problem
When I select the Animation command an error message appears:
There are no animation controller files in your Plug-ins folder.
Anyone know how to fix this?
WXP VW Designer 12..5.2
Edited by ErichR
Why not just post a list of the files in your Plug-in Folder... obviously something is missing ; )
actually it takes about 30secs:
/Applications/VectorWorks 11.5.1/Plug-Ins] ejarmstr% ls -R
0000-ISO01.vso Export Quicktime Movie Restore Redline.vsm
11.5 Prefix Classes.vsm ExtendedProperties Revision Cloud Tool.vst
2D Polys to 3D Contours.vsm Extension Spring - Front.vso Revision Cloud.vso
3d Dimension conversion.vsm Exterior Wall Dimensioner.vsm Revision Marker.vso
ADA.vst External_L.vst Rigid Insulation.vso
AW Camera Path.vso External_R.vst Roadway (Bezier).vso
AW Camera.vso ExtrudeAlongPath Roadway (Curved).vso
AW Class Visibility.vso ExtrudeAlongPathMenu Roadway (NURBS).vso
AW Light.vso Eyedropper Tool Roadway (Straight).vso
AW Moving Object Path.vso File Path.vso Roadway (Tee).vso
AW Moving Object.vso Find-Replace Text.vsm Roller Bearing.vso
AW Rotating Object.vso Fireplace.vso RoofFramer
AW Sliding Object.vso Fit To Objects Roofer
AW Transparency.vso FitWallsToRoof Room Finish Library.vsm
About Neatworkz....vsm FixWalls.vst Room Name Simple.vso
Add Device To Library.vst Flowchart Link Tool.vst Room Name.vso
Add Text to Database.vsm Flowchart Link.vso Rotate Drawing v11
Adjacency Matrix.vso Flowchart Node.vso Round Tubing (Inch).vso
Adjacency Score.vso Framing Member Tool.vst Round Tubing (Metric).vso
Align Layer Views FramingMember Sample 2D Path Obj.vso
Align menu French Door 2.vso Sample 3D Path Obj.vso
AlignDistributeLib GDP Class Activate.vsm Sample Linear Obj.vso
Angle (Inch).vso GDP Class Deactivate.vsm Sample Rectangular Obj.vso
Angle (Metric).vso GDP Class Isolate.vsm Scale Bar.vso
AnimationWorks....vsm GDP Group to None.vsm Seating Layout.vso
Annotate Segments.vsm GDP Selector => Fill.vsm Section Note.vsm
Arc by Segment Length.vsm GDP Selector => Line&Fill.vsm Select Wall Type.vsm
Arc into Segments.vsm GDP Selector => Line.vsm Send to Surface.vsm
Assign Door Hdw Tool.vst GDP Total Length.vsm Set Default Symbol Class.vsm
Assign Room Finish Tool.vst GWB.vso Set Key Model.vsm
Attach Handrails.vsm General Notes.vso Set URL.vsm
Attach Record.vsm GeometryLib Set WinDoor 11 Defaults....vsm
AttachXYZ to Symbol.vsm Get Device From Library.vst Shaft Break.vso
Audio Jack.vst Get3DWall Info.vst Shear
Audio TP.vst GetSymbolName.vst Shelving Unit.vso
Ball Bearing.vso Golden Rectangle.vso Show - Hide details.vsm
Base Cabinet.vso Golden Triangle.vso Show Control Bounds.vsm
Batch Print.vsm Goto URL.vsm Show Control IDs.vsm
Bath-Shower.vso Grab Bars.vso Show Control Origin.vsm
Batt Insulation.vso Grid - Polar.vso Show or Hide 3D.vsm
BenchMarkXYtext.vst Grid - Rectangular.vso Show or Hide Redlines.vsm
BlackBack.vst Grid Bubble.vso Show-Hide WinDoor Detail....vsm
Board.vso Grid Method Entry.vsm Simple Beam Calculator.vsm
Bolt and Nut - inch.vso Guardrail (Curved).vso Simple Door 2.vso
Bolt and Nut - mm.vso Guardrail (Straight).vso Simple Elevator.vso
Box Object.vso Guides Simple Window 2.vso
Break Line.vso HVAC Damper.vso SineWave.vso
Bridge Line.vso HVAC Diffuser.vso Site Model Section.vsm
Build Custom Dialog....vsm HVAC Elbow Duct.vso Site Model.vsm
CableLengthData_D.vss HVAC Flex Duct.vso Sliding Glass Door 2.vso
Callout Tool.vst HVAC Outlet.vso Slope Dimension.vso
Callout.vso HVAC Splitter.vso Slot.vso
Campanile.vso HVAC Straight Duct.vso Socket B Loop.vst
Cap Screw (Inch).vso HVAC Transition.vso Socket B.vst
Cap Screw (Metric).vso HVAC Vertical Duct.vso Socket L Loop.vst
Ceiling Grid.vso HVAC Vertical Elbow.vso Socket L.vst
Chain Extrude.vso Handrail (Curved).vso Socket R Loop.vst
Change All Fields.vsm Handrail (Straight).vso Socket R.vst
Change One Field.vsm HelixSpiral Sort Worksheet Rows....vsm
Change Symbol Attrs.vsm HelixSpiralMenu Space Link Tool.vst
Channel (Inch).vso Hex Bolt (Inch).vso Space Link.vso
Channel (Metric).vso Hex Bolt (Metric).vso Space Menu.vwplugin
Check Drawing.vsm Hide Control Bounds.vsm Space Tool.vwplugin
Check Layout.vsm Hide Control IDs.vsm Space.vso
CheckSpelling Hide Control Origin.vsm Space.vwobject
Circuiting Tool.vst Hole Pattern.vso Sphere Object.vso
Circular Stair.vso I-Beam (Inch).vso Spiral.vso
Class Attribute Mode.vsm I-Beam (Metric).vso Spur Gear.vso
Class Line 0-5 ICON_ZoomLine.bmp Square Tubing (Inch).vso
Clear Markup.vsm ICON_ZoomLine.jpg Square Tubing (Metric).vso
Clear Print Settings.vss ID Label Tool.vst Stacking Diagram.vso
Clothes Rod.vso ID Leader.vso Stair.vso
ColPalette.rsrc IFCEntity.vwobject Stake Object.vso
ColourByLegend.vsm IFCExport.vwplugin Standard Naming.vsm
Column.vso IFCImport.vwplugin Stipple.vso
Comm Device.vso IFCLibrary.vwlibrary Storypole.vso
Common IFCMenu.vwplugin Sun Position
Compare List & Drawing.vsm IP Resources.rsrc Switch.vso
Compartment Sink.vso Import Adjacency Matrix.vsm Table and Chairs.vso
Complex Window 2.vso Import Dialog Script.vsm Table.vso
Compression Spring 1.vso Import Survey File.vsm TapeMeasureTool
Conductor Sizing Calc.vsm Incandescent Fixture.vso TaperedExtrude
Conduit Sizing Calc.vsm Includes TaperedExtrudeMenu
Cone Object.vso Info Editor Task Manager.vsm
Connect (Round).vst Issue Manager.vsm Tee (Inch).vso
Connect.vst Joist.vso Tee (Metric).vso
Connect_by_Arrows.vst K_Explode.vst Terminator.vst
Constrain Angle.vst Keynote Legend.vso Textured Prop
Constrain Coincident.vst LandruCurvedCurtain Folder Tile.vsm
Constrain Colinear.vst LandruNoteBox.vso Toggle Viewport Crop.vsm
Constrain Concentric.vst LandruStage.vso ToggleViewportClasses
Constrain Distance.vst Line into Segments.vsm Toilet Stall.vso
Constrain Horiz Distance.vst List Symbols.vsm Torus Object.vso
Constrain Horiz-Vertical.vst Lock Washer (Inch).vso Trim Tool
Constrain Parallel.vst Lock Washer (Metric).vso TrueType To Polyline
Constrain Perpendicular.vst MDU.vst Truss Standard 4 Web.vso
Constrain Radius.vst MacHasp11EuroLib URLs Folder
Constrain Tangent.vst Machine Screw (Inch).vso Untitled Plug-in.vst
Constrain Vertical Distance.vst Machine Screw (Metric).vso Update to V2 Objects.vsm
Convert Color.vsm Make Cable List.vsm UpdateDateStamp.vst
Convert Old Notes to New.vsm Make Device List.vsm UpdateDateTimeStamp.vsm
Counter Top.vso Make Ext Cable List.vsm UpdateLocationInfo.vsm
Create Color Chart.vsm Make JF Strips.vsm Utility Cabinet.vso
Create Drawing List.vsm Make TP Strips.vsm VA Create Record.vsm
Create Joists from Poly.vsm MakeDevice.vst VA Create Schedule.vsm
Create Panel Riser Diag.vsm Massing Model.vso VA Records and Schedules.vsm
Create Panel Schedule.vsm Material Fill.vsm VA Redline Auditor.vsm
Create Piping Runs.vsm Material Note.vsm VA Set Project Prefs.vsm
Create Polys from Walls.vsm Matrix.vst VB Center Page on Rect.vst
Create Rafters from Roof.vsm Merge text.vsm VB Chain Maker
Create Redline Status WS.vsm Model Setup.vsm VB Class menu
Create Rm Finish Legend.vsm Model View Tool.vst VB Layer menu
Create Seating Layout.vsm Model to Floorplan.vsm VB Level Dimension.vso
Create Solar Animation.vsm Modify Layers and Classes.vsm VB Magic Wand
Create Spaces from Polys.vsm MoveDevices.vst VB Optimize Drawing
Create Spaces from Walls.vsm MovePage VB Prefs menu
Create Standard Viewports.vsm MoveTest.vsm VB Rotate Drawing
Create Standard Views.vsm Mullion.vso VB Strech
Create Viewports from Views.vsm MultiConnect.vsm VB Tape Measure Tool
Create Views from Viewports.vsm Neatworkz_readme.txt VB Vector Move
Create Walls from Polygon.vsm North Arrow.vso VB Vector Move.vwplugin
Create Walls from Spaces.vsm Number Cables....vsm VB XY.vso
Create WinDoor Elevation....vsm Number Drawing From List.vsm VB Zoom Dynamic
Create3D_Object.vsm Number Selected Cables.vsm VDA.vst
CreateLegend.vsm Numbering.xxt VP Crops on Design Layer.vsm
CurvePolyParameteric.vsm Nut (Inch).vso VS Compiler Mode.vsm
Custom Selection 2.vsm Nut (Metric).vso VS SharedLib
Cut and Fill.vsm Objects from Polyline.vsm VWLibrary
Cutting Plane.vso Offset Tool VWPluginLibraryRoutines.h
Cylinder Object.vso Open-Close WinDoor 3D....vsm VWPluginLibraryRoutines.p
DB4 - Check Box.vso Orbit Animator VW_Arch
DB4 - Dialog Window.vso Overhead Door 2.vso VW_Land
DB4 - Edit Integer.vso OzCAD Preferences VW_Mech
DB4 - Edit Real.vso Parabaloid Object.vso VectorBITS Preferences
DB4 - Edit Text.vso Parking Spaces.vso VectorScriptEditor
DB4 - Group Box.vso Path Animator Video Jack.vst
DB4 - Image Panel.vso Picch.vst Video TP.vst
DB4 - List Box.vso Pick up Redline.vsm View Manager.vsm
DB4 - Pulldown Menu.vso Pilaster.vso ViewPack 11.5 Resources.qtr
DB4 - Push Button.vso Pipe Fitting.vso ViewPack 11.5 Resources.rsrc
DB4 - Radio Button.vso Piping Connection.vso ViewPack Preferences.vsm
DB4 - Slider.vso Piping Run.vso Volumetric Properties.vsm
DB4 - Static Text.vso Piping.vso Wall Cabinet.vso
DB4 - System Color.vso Plain Washer (Inch).vso Wall Type Tool (Round).vst
Data Plain Washer (Metric).vso Wall Type Tool (Straight).vst
Data Jack.vst Plant.vso WeightInfo Folder
Data Stamp.vso Plug-In Support Wide Flange (Inch).vso
Data TP.vst Plywood.vso Wide Flange (Metric).vso
Delete Jack.vst Points2Polyline.vsm WinDoor 6.0.vso
Desk.vso PointsOnPolyline Tool.vst Window.vso
Detach Record.vsm Property Line Tool.vst WindowWall(Curved).vso
Detail Cut Wood.vso Property Line.vso WindowWall(Straight).vso
Dictionaries Protractor Tool Workspace Editor
Digital Terrain Modeling Purge Workstation Counter.vso
Disconnect Device.vst Put Devices on RackLayout.vsm Workstation Overhead.vso
Disconnect.vst Pyramid Object.vso Workstation Panel.vso
Display or Hide Constraints.vsm Quarter Arc.vso Workstation Pedestal.vso
Document Setup.vsm QueryCircuit.vst XMLLib
Door Hardware Library.vsm Rack19in2D.vso ZoomLine Plug-in.vst
Door and Sidelights.vso RackBlankPanel.vso ZoomLineThickness.vss
Door.vso RackEquipItem.vso class, set object default.vsm
Draw WinDoor Objects.vst RackRuler.vso fastener.vso
Drawing Border-Arch.vso Rafter.vso fern.vso
Drawing Border-Cust.vso Railing.vso match attributes.vst
Drawing Border-no TB.vso Railing_ReadMe.rtf picchetti 1.2.vss
Drawing Border.vso Ramp.vso readme.txt
Drawing Label.vso ReRoute Circuits.vst test 3D Path Obj.vso
Drilled Footing.vso Read Color Palette.vsm texteyedropper Folder
Duplicate Along Path Receptacle.vso xplode - nudge X+.vst
Duplicate Symbol In Wall Reconcile Notes.vsm xplode - nudge X-.vst
Dwg Label Simple.vso Rectagon.vso xplode - nudge Y+.vst
Edit Circuiting Tool.vst Rectagon11.vso xplode - nudge Y-.vst
EditDevice.vst Rectangular Obj.vso xplode - nudge Z+.vst
EditShader Rectangular Tubing (Inch).vso xplode - nudge Z-.vst
EditSocket.vst Rectangular Tubing (Metric).vso xplode - 3D quote.vst
Elevation Benchmark.vso Redline Object.vso xplode - assign.vsm
Ellipsoid Object.vso Redline Tool.vst xplode - detach.vsm
Engineering Properties.vsm Reference Marker.vso xplode - expl. to saved....vsm
Enter Viewport from List.vsm RenderSettings xplode - explode 3D....vsm
Enter-Exit Viewport.vsm Renumber Controls.vsm xplode - implode....vsm
Escalator.vso Reset Control Tree Pathing.vsm xplode - nudge....vsm
ExplodeTool Folder Reshaper 11.vsm xplode - save position....vsm
Export DOE-2.vsm Resize xplode - select....vsm
./Class Line 0-5:
Icon? please read me
./Common:
Data
./Common/Data:
00_Arch_Sheets.mcd Notes Task Data.txt
Angle-Inch.txt Notes Callout Filters.txt Tee-Inch.txt
Angle-Metric.txt Notes General Filters.txt Tee-Metric.txt
Channel-Inch.txt Preferences.xml UpdateResources.mcd
Channel-Metric.txt Reconcile Notes.txt VA Setup Data-Metric.mcd
Drawing Border Data-Arch.txt RectangularTubing-Inch.txt VA Setup Data.mcd
DwgSizes.txt RectangularTubing-Metric.txt WFlange-Inch.txt
IBeam-Inch.txt RoundTubing-Inch.txt WFlange-Metric.txt
IBeam-Metric.txt RoundTubing-Metric.txt Wall Hatches.vss
ID Prefs.txt SquareTubing-Inch.txt Wall Type Library.txt
ID_Symbols.mcd SquareTubing-Metric.txt
./Common/Data/Notes:
Callouts.txt General Notes.txt
./Data:
ADAdata.txt DeviceLib.txt SignalTypes.txt currentversion.txt
AW_Constants.vss JFdata.txt TPdata.txt
ConnectorTypes.txt ReshaperKeys VDAdata.txt
./Dictionaries:
AmericanEnglish.clx UserDictionary.txt
./ExplodeTool Folder:
Explode.txt
./IFCEntity.vwobject:
Contents
./IFCEntity.vwobject/Contents:
Info.plist MacOS Resources
./IFCEntity.vwobject/Contents/MacOS:
IFCEntity
./IFCEntity.vwobject/Contents/Resources:
IFCEntity.qtr
./IFCExport.vwplugin:
Contents
./IFCExport.vwplugin/Contents:
./IFCExport.vwplugin/Contents/MacOS:
IFCExport
./IFCExport.vwplugin/Contents/Resources:
IFCExport.qtr
./IFCImport.vwplugin:
Contents
./IFCImport.vwplugin/Contents:
./IFCImport.vwplugin/Contents/MacOS:
IFCImport
./IFCImport.vwplugin/Contents/Resources:
IFCImport.qtr
./IFCLibrary.vwlibrary:
Contents
./IFCLibrary.vwlibrary/Contents:
./IFCLibrary.vwlibrary/Contents/MacOS:
IFCLibrary
./IFCLibrary.vwlibrary/Contents/Resources:
IFCLibrary.qtr
./IFCMenu.vwplugin:
Contents
./IFCMenu.vwplugin/Contents:
./IFCMenu.vwplugin/Contents/MacOS:
IFCMenu
./IFCMenu.vwplugin/Contents/Resources:
IFCMenu.qtr
./Includes:
./Info Editor:
Bin Data Manual.pdf Read Me.rtf
./Info Editor/Bin:
Info Editor.vsm
./Info Editor/Data:
Door Types to Import.txt Popup Values Types.xml
./Info Editor/Data/Popup Values:
Door
./Info Editor/Data/Popup Values/Door:
Door Height.txt Door Width.txt
./LandruCurvedCurtain Folder:
Curtain From....vsm LandruCurtain 1.0.vso
./OzCAD Preferences:
WMMasterPref.txt
./Rotate Drawing v11:
Icon? Merge text.vsm
Install Menu command.url Rotate Drawing.url
./Space Menu.vwplugin:
Contents
./Space Menu.vwplugin/Contents:
./Space Menu.vwplugin/Contents/MacOS:
Space Menu
./Space Menu.vwplugin/Contents/Resources:
Space Menu.qtr
./Space Tool.vwplugin:
Contents
./Space Tool.vwplugin/Contents:
./Space Tool.vwplugin/Contents/MacOS:
Space Tool
./Space Tool.vwplugin/Contents/Resources:
Space Tool.qtr
./Space.vwobject:
Contents
./Space.vwobject/Contents:
./Space.vwobject/Contents/MacOS:
Space
./Space.vwobject/Contents/Resources:
Space.qtr
./URLs Folder:
ReadMe.txt
./VB Vector Move.vwplugin:
Contents
./VB Vector Move.vwplugin/Contents:
./VB Vector Move.vwplugin/Contents/MacOS:
VB Vector Move
./VB Vector Move.vwplugin/Contents/Resources:
VB Vector Move.qtr
./VW_Arch:
Data Interfaces
./VW_Arch/Data:
AWG.txt Joist Sizes.txt Purlin Spacing.txt
Beam Sizes.txt Joist Spacing.txt Rafter Sizes.txt
BoltAndNut_inch.txt Lumber Sizes.txt Rafter Spacing.txt
BoltAndNut_mm.txt Model To Floorplan.txt Ridge Sizes.txt
Conductor.txt Plate Sizes.txt Sill Sizes.txt
Conduit.txt Post Sizes.txt Sleeper Sizes.txt
Dormer Rafter Sizes.txt Prefs_01 Sleeper Spacing.txt
Fixtures.MCD Prefs_02 Strut Sizes.txt
GSA_ABLT1.txt Prefs_03 Stud Sizes.txt
GSA_SCLT1.txt Prefs_04 Trimmer Sizes.txt
GSA_STBCLT1.txt Prefs_05 VA2_Preference_Set_Paths.txt
GSA_SZLT1.txt Prefs_Def Wire.txt
Hip Rafter Sizes.txt Purlin Sizes.txt
./VW_Arch/Data/Prefs_01:
Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt
Door Hdw Record.txt Plant Record.txt Wall Record.txt
Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt
Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt
Door Schedule.txt Rm Finish Schedule.txt Window Record.txt
Equipment Record.txt Room Finish Library.txt Window Schedule.txt
Equipment Schedule.txt Room Record.txt
Irrigation Head.txt VA2 Records and Schedules.txt
./VW_Arch/Data/Prefs_02:
./VW_Arch/Data/Prefs_03:
./VW_Arch/Data/Prefs_04:
./VW_Arch/Data/Prefs_05:
./VW_Arch/Data/Prefs_Def:
./VW_Arch/Interfaces:
HVAC_Duct_K.vss
./VW_Land:
Interfaces
./VW_Land/Interfaces:
Import Survey File_D.vss
./VW_Mech:
Data Includes
./VW_Mech/Data:
CapSlottedFillister-Inch.txt HexBoltStruct-Metric.txt MachOval-Inch.txt
CapSlottedFlat-Inch.txt HexScrew-Inch.txt MachOval-Metric.txt
CapSlottedRound-Inch.txt HexScrew-Metric.txt MachPan-Inch.txt
CapSocButton-Inch.txt LockWasher-Inch.txt MachPan-Metric.txt
CapSocButton-Metric.txt LockWasher-Metric.txt MachRound-Inch.txt
CapSocFlat-Inch.txt MachBind-Inch.txt MachTruss-Inch.txt
CapSocFlat-Metric.txt MachFill-Inch.txt Nut-Metric.txt
CapSocHead-Inch.txt MachFlat-Metric.txt NutHexJam-Inch.txt
CapSocHead-Metric.txt MachFlat100-Inch.txt NutRegularHex-Inch.txt
HexBolt-Inch.txt MachFlat82-Inch.txt NutSlotted-Inch.txt
HexBolt-Metric.txt MachHex-Inch.txt NutSquare-Inch.txt
HexBoltFinished-Inch.txt MachHex-Metric.txt PlainWasher-Metric.txt
HexBoltFinished-Metric.txt MachHexF-Metric.txt PlainWasher-TypeA.txt
HexBoltHeavy-Inch.txt MachHexS-Inch.txt PlainWasher-TypeB.txt
HexBoltHeavy-Metric.txt MachHexW-Inch.txt SquareBolt-Inch.txt
HexBoltStruct-Inch.txt MachHexWS-Inch.txt
./VW_Mech/Includes:
VWMechanical_K.vss
./WeightInfo Folder:
Weight_info.vsm readMe.pdf specificWeightsTable.txt
./texteyedropper Folder:
TextEyeDropperDocs.TXT
Incidentally, the NNA people who frequent the board are probably gearing up for AIA Boston this week.
Edited by brudgers
islandmon,
I for one do appreciate all that you contribute to this forum. Thank you.
Seemed a bit unnecessary for Islandmon to list a gazillion v11.5 files, when my issue is with v12.
I called VW Tech Support.
After much fooling around, including a tortuous uninstall and a reinstall, it appears that their own v12.5.3 has the same problem. Possibly it's an issue with QuickTime.
One wonders if any of the Windows versions of v12+ work for animation. Tech is to get back to me.
...And the process he was suggesting is so different for other versions of Vectorworks.
I agree, Islandmon is always a help, learned much from his posts, and even more when he posts a file and you can see how he sets up a VW project, very very helpful.
Eric,
Please send a private message with an email address so that we can send you these missing plug-ins.
Thanks
Edited by Tech
Tech (Alicia) solved it and emailed the missing plug-in files.
V12 was supposed to have been complete, but was missing them, so the animation command was non-functional from the original v12 through v12.5.3.
Case Closed.
Thanks!
Thank you for the update. Glad that your situation is resolved. However, your phrasing suggests that other users should be experiencing missing plug-ins. Could you elaborate on whether this situation is isolated to your installation or, as you say, that V12 from VW is missing these plug-ins. If so, then all of us will certainly want to receive these plug-ins that are missing.
I'm back ; ) .. hey glad that the problem was resolved ...
all i wanted to show was that it is easy to create a recursive listing of any path-able directory( even works via ftp, too ) . The old v11.5.1 was just an example of the process using Terminal command > ls -R , which is pretty basic and easy to do ( Win command line has somewhat similar syntax ). I apologize for the length of the attached list , but it serves to illustrate the recursive nature of the nested directory listings. This can be very helpful when there is a question regarding the existence of various plug-in & includes components not only in VW with with all applications & installs.
My humble thanx to those who submitted positive support comments .
Kevin - Tech said that v12 did ship with the proper plug-in files, but didn't have any explanation why in their copy and mine they were absent. The v12 installation disk does have the files, they say, but updates do not.
BTW, since I knew that the animation dialog box had two options in its upper pull-down, I did a search for 'path' and one for 'orbit' (in v11, which did work) in the Plug-ins folder, and came up with 4 files. This was before I called tech. I stuck those files in the V12.5.3 plug-ins folder. Voila! the animation dialog box appeared, but didn't have any functionality.
Then the call to tech. Coincidentally, I was on the right track, because the 4 files tech emailed me were the same ones (but v12) I had gleaned from v11.
These are the elusive files:
OrbitAnimator.dll
OrbitAnimator.qtr
PathAnimator.dll
PathAnimator.qtr
Edited by ErichR
