ErichR Posted May 9, 2008 Share Posted May 9, 2008 (edited) When I select the Animation command an error message appears: There are no animation controller files in your Plug-ins folder. Anyone know how to fix this? WXP VW Designer 12..5.2 Edited May 9, 2008 by ErichR Quote Link to comment
ErichR Posted May 12, 2008 Author Share Posted May 12, 2008 A Response from Tech maybe? Quote Link to comment
islandmon Posted May 13, 2008 Share Posted May 13, 2008 Why not just post a list of the files in your Plug-in Folder... obviously something is missing ; ) Quote Link to comment
ErichR Posted May 13, 2008 Author Share Posted May 13, 2008 You can't be serious. There are hundreds of files in at least 15 folders. Quote Link to comment
ErichR Posted May 13, 2008 Author Share Posted May 13, 2008 Tech gone for the day? Quote Link to comment
brudgers Posted May 13, 2008 Share Posted May 13, 2008 Try calling technical support directly. Quote Link to comment
islandmon Posted May 13, 2008 Share Posted May 13, 2008 actually it takes about 30secs: /Applications/VectorWorks 11.5.1/Plug-Ins] ejarmstr% ls -R 0000-ISO01.vso Export Quicktime Movie Restore Redline.vsm 11.5 Prefix Classes.vsm ExtendedProperties Revision Cloud Tool.vst 2D Polys to 3D Contours.vsm Extension Spring - Front.vso Revision Cloud.vso 3d Dimension conversion.vsm Exterior Wall Dimensioner.vsm Revision Marker.vso ADA.vst External_L.vst Rigid Insulation.vso AW Camera Path.vso External_R.vst Roadway (Bezier).vso AW Camera.vso ExtrudeAlongPath Roadway (Curved).vso AW Class Visibility.vso ExtrudeAlongPathMenu Roadway (NURBS).vso AW Light.vso Eyedropper Tool Roadway (Straight).vso AW Moving Object Path.vso File Path.vso Roadway (Tee).vso AW Moving Object.vso Find-Replace Text.vsm Roller Bearing.vso AW Rotating Object.vso Fireplace.vso RoofFramer AW Sliding Object.vso Fit To Objects Roofer AW Transparency.vso FitWallsToRoof Room Finish Library.vsm About Neatworkz....vsm FixWalls.vst Room Name Simple.vso Add Device To Library.vst Flowchart Link Tool.vst Room Name.vso Add Text to Database.vsm Flowchart Link.vso Rotate Drawing v11 Adjacency Matrix.vso Flowchart Node.vso Round Tubing (Inch).vso Adjacency Score.vso Framing Member Tool.vst Round Tubing (Metric).vso Align Layer Views FramingMember Sample 2D Path Obj.vso Align menu French Door 2.vso Sample 3D Path Obj.vso AlignDistributeLib GDP Class Activate.vsm Sample Linear Obj.vso Angle (Inch).vso GDP Class Deactivate.vsm Sample Rectangular Obj.vso Angle (Metric).vso GDP Class Isolate.vsm Scale Bar.vso AnimationWorks....vsm GDP Group to None.vsm Seating Layout.vso Annotate Segments.vsm GDP Selector => Fill.vsm Section Note.vsm Arc by Segment Length.vsm GDP Selector => Line&Fill.vsm Select Wall Type.vsm Arc into Segments.vsm GDP Selector => Line.vsm Send to Surface.vsm Assign Door Hdw Tool.vst GDP Total Length.vsm Set Default Symbol Class.vsm Assign Room Finish Tool.vst GWB.vso Set Key Model.vsm Attach Handrails.vsm General Notes.vso Set URL.vsm Attach Record.vsm GeometryLib Set WinDoor 11 Defaults....vsm AttachXYZ to Symbol.vsm Get Device From Library.vst Shaft Break.vso Audio Jack.vst Get3DWall Info.vst Shear Audio TP.vst GetSymbolName.vst Shelving Unit.vso Ball Bearing.vso Golden Rectangle.vso Show - Hide details.vsm Base Cabinet.vso Golden Triangle.vso Show Control Bounds.vsm Batch Print.vsm Goto URL.vsm Show Control IDs.vsm Bath-Shower.vso Grab Bars.vso Show Control Origin.vsm Batt Insulation.vso Grid - Polar.vso Show or Hide 3D.vsm BenchMarkXYtext.vst Grid - Rectangular.vso Show or Hide Redlines.vsm BlackBack.vst Grid Bubble.vso Show-Hide WinDoor Detail....vsm Board.vso Grid Method Entry.vsm Simple Beam Calculator.vsm Bolt and Nut - inch.vso Guardrail (Curved).vso Simple Door 2.vso Bolt and Nut - mm.vso Guardrail (Straight).vso Simple Elevator.vso Box Object.vso Guides Simple Window 2.vso Break Line.vso HVAC Damper.vso SineWave.vso Bridge Line.vso HVAC Diffuser.vso Site Model Section.vsm Build Custom Dialog....vsm HVAC Elbow Duct.vso Site Model.vsm CableLengthData_D.vss HVAC Flex Duct.vso Sliding Glass Door 2.vso Callout Tool.vst HVAC Outlet.vso Slope Dimension.vso Callout.vso HVAC Splitter.vso Slot.vso Campanile.vso HVAC Straight Duct.vso Socket B Loop.vst Cap Screw (Inch).vso HVAC Transition.vso Socket B.vst Cap Screw (Metric).vso HVAC Vertical Duct.vso Socket L Loop.vst Ceiling Grid.vso HVAC Vertical Elbow.vso Socket L.vst Chain Extrude.vso Handrail (Curved).vso Socket R Loop.vst Change All Fields.vsm Handrail (Straight).vso Socket R.vst Change One Field.vsm HelixSpiral Sort Worksheet Rows....vsm Change Symbol Attrs.vsm HelixSpiralMenu Space Link Tool.vst Channel (Inch).vso Hex Bolt (Inch).vso Space Link.vso Channel (Metric).vso Hex Bolt (Metric).vso Space Menu.vwplugin Check Drawing.vsm Hide Control Bounds.vsm Space Tool.vwplugin Check Layout.vsm Hide Control IDs.vsm Space.vso CheckSpelling Hide Control Origin.vsm Space.vwobject Circuiting Tool.vst Hole Pattern.vso Sphere Object.vso Circular Stair.vso I-Beam (Inch).vso Spiral.vso Class Attribute Mode.vsm I-Beam (Metric).vso Spur Gear.vso Class Line 0-5 ICON_ZoomLine.bmp Square Tubing (Inch).vso Clear Markup.vsm ICON_ZoomLine.jpg Square Tubing (Metric).vso Clear Print Settings.vss ID Label Tool.vst Stacking Diagram.vso Clothes Rod.vso ID Leader.vso Stair.vso ColPalette.rsrc IFCEntity.vwobject Stake Object.vso ColourByLegend.vsm IFCExport.vwplugin Standard Naming.vsm Column.vso IFCImport.vwplugin Stipple.vso Comm Device.vso IFCLibrary.vwlibrary Storypole.vso Common IFCMenu.vwplugin Sun Position Compare List & Drawing.vsm IP Resources.rsrc Switch.vso Compartment Sink.vso Import Adjacency Matrix.vsm Table and Chairs.vso Complex Window 2.vso Import Dialog Script.vsm Table.vso Compression Spring 1.vso Import Survey File.vsm TapeMeasureTool Conductor Sizing Calc.vsm Incandescent Fixture.vso TaperedExtrude Conduit Sizing Calc.vsm Includes TaperedExtrudeMenu Cone Object.vso Info Editor Task Manager.vsm Connect (Round).vst Issue Manager.vsm Tee (Inch).vso Connect.vst Joist.vso Tee (Metric).vso Connect_by_Arrows.vst K_Explode.vst Terminator.vst Constrain Angle.vst Keynote Legend.vso Textured Prop Constrain Coincident.vst LandruCurvedCurtain Folder Tile.vsm Constrain Colinear.vst LandruNoteBox.vso Toggle Viewport Crop.vsm Constrain Concentric.vst LandruStage.vso ToggleViewportClasses Constrain Distance.vst Line into Segments.vsm Toilet Stall.vso Constrain Horiz Distance.vst List Symbols.vsm Torus Object.vso Constrain Horiz-Vertical.vst Lock Washer (Inch).vso Trim Tool Constrain Parallel.vst Lock Washer (Metric).vso TrueType To Polyline Constrain Perpendicular.vst MDU.vst Truss Standard 4 Web.vso Constrain Radius.vst MacHasp11EuroLib URLs Folder Constrain Tangent.vst Machine Screw (Inch).vso Untitled Plug-in.vst Constrain Vertical Distance.vst Machine Screw (Metric).vso Update to V2 Objects.vsm Convert Color.vsm Make Cable List.vsm UpdateDateStamp.vst Convert Old Notes to New.vsm Make Device List.vsm UpdateDateTimeStamp.vsm Counter Top.vso Make Ext Cable List.vsm UpdateLocationInfo.vsm Create Color Chart.vsm Make JF Strips.vsm Utility Cabinet.vso Create Drawing List.vsm Make TP Strips.vsm VA Create Record.vsm Create Joists from Poly.vsm MakeDevice.vst VA Create Schedule.vsm Create Panel Riser Diag.vsm Massing Model.vso VA Records and Schedules.vsm Create Panel Schedule.vsm Material Fill.vsm VA Redline Auditor.vsm Create Piping Runs.vsm Material Note.vsm VA Set Project Prefs.vsm Create Polys from Walls.vsm Matrix.vst VB Center Page on Rect.vst Create Rafters from Roof.vsm Merge text.vsm VB Chain Maker Create Redline Status WS.vsm Model Setup.vsm VB Class menu Create Rm Finish Legend.vsm Model View Tool.vst VB Layer menu Create Seating Layout.vsm Model to Floorplan.vsm VB Level Dimension.vso Create Solar Animation.vsm Modify Layers and Classes.vsm VB Magic Wand Create Spaces from Polys.vsm MoveDevices.vst VB Optimize Drawing Create Spaces from Walls.vsm MovePage VB Prefs menu Create Standard Viewports.vsm MoveTest.vsm VB Rotate Drawing Create Standard Views.vsm Mullion.vso VB Strech Create Viewports from Views.vsm MultiConnect.vsm VB Tape Measure Tool Create Views from Viewports.vsm Neatworkz_readme.txt VB Vector Move Create Walls from Polygon.vsm North Arrow.vso VB Vector Move.vwplugin Create Walls from Spaces.vsm Number Cables....vsm VB XY.vso Create WinDoor Elevation....vsm Number Drawing From List.vsm VB Zoom Dynamic Create3D_Object.vsm Number Selected Cables.vsm VDA.vst CreateLegend.vsm Numbering.xxt VP Crops on Design Layer.vsm CurvePolyParameteric.vsm Nut (Inch).vso VS Compiler Mode.vsm Custom Selection 2.vsm Nut (Metric).vso VS SharedLib Cut and Fill.vsm Objects from Polyline.vsm VWLibrary Cutting Plane.vso Offset Tool VWPluginLibraryRoutines.h Cylinder Object.vso Open-Close WinDoor 3D....vsm VWPluginLibraryRoutines.p DB4 - Check Box.vso Orbit Animator VW_Arch DB4 - Dialog Window.vso Overhead Door 2.vso VW_Land DB4 - Edit Integer.vso OzCAD Preferences VW_Mech DB4 - Edit Real.vso Parabaloid Object.vso VectorBITS Preferences DB4 - Edit Text.vso Parking Spaces.vso VectorScriptEditor DB4 - Group Box.vso Path Animator Video Jack.vst DB4 - Image Panel.vso Picch.vst Video TP.vst DB4 - List Box.vso Pick up Redline.vsm View Manager.vsm DB4 - Pulldown Menu.vso Pilaster.vso ViewPack 11.5 Resources.qtr DB4 - Push Button.vso Pipe Fitting.vso ViewPack 11.5 Resources.rsrc DB4 - Radio Button.vso Piping Connection.vso ViewPack Preferences.vsm DB4 - Slider.vso Piping Run.vso Volumetric Properties.vsm DB4 - Static Text.vso Piping.vso Wall Cabinet.vso DB4 - System Color.vso Plain Washer (Inch).vso Wall Type Tool (Round).vst Data Plain Washer (Metric).vso Wall Type Tool (Straight).vst Data Jack.vst Plant.vso WeightInfo Folder Data Stamp.vso Plug-In Support Wide Flange (Inch).vso Data TP.vst Plywood.vso Wide Flange (Metric).vso Delete Jack.vst Points2Polyline.vsm WinDoor 6.0.vso Desk.vso PointsOnPolyline Tool.vst Window.vso Detach Record.vsm Property Line Tool.vst WindowWall(Curved).vso Detail Cut Wood.vso Property Line.vso WindowWall(Straight).vso Dictionaries Protractor Tool Workspace Editor Digital Terrain Modeling Purge Workstation Counter.vso Disconnect Device.vst Put Devices on RackLayout.vsm Workstation Overhead.vso Disconnect.vst Pyramid Object.vso Workstation Panel.vso Display or Hide Constraints.vsm Quarter Arc.vso Workstation Pedestal.vso Document Setup.vsm QueryCircuit.vst XMLLib Door Hardware Library.vsm Rack19in2D.vso ZoomLine Plug-in.vst Door and Sidelights.vso RackBlankPanel.vso ZoomLineThickness.vss Door.vso RackEquipItem.vso class, set object default.vsm Draw WinDoor Objects.vst RackRuler.vso fastener.vso Drawing Border-Arch.vso Rafter.vso fern.vso Drawing Border-Cust.vso Railing.vso match attributes.vst Drawing Border-no TB.vso Railing_ReadMe.rtf picchetti 1.2.vss Drawing Border.vso Ramp.vso readme.txt Drawing Label.vso ReRoute Circuits.vst test 3D Path Obj.vso Drilled Footing.vso Read Color Palette.vsm texteyedropper Folder Duplicate Along Path Receptacle.vso xplode - nudge X+.vst Duplicate Symbol In Wall Reconcile Notes.vsm xplode - nudge X-.vst Dwg Label Simple.vso Rectagon.vso xplode - nudge Y+.vst Edit Circuiting Tool.vst Rectagon11.vso xplode - nudge Y-.vst EditDevice.vst Rectangular Obj.vso xplode - nudge Z+.vst EditShader Rectangular Tubing (Inch).vso xplode - nudge Z-.vst EditSocket.vst Rectangular Tubing (Metric).vso xplode - 3D quote.vst Elevation Benchmark.vso Redline Object.vso xplode - assign.vsm Ellipsoid Object.vso Redline Tool.vst xplode - detach.vsm Engineering Properties.vsm Reference Marker.vso xplode - expl. to saved....vsm Enter Viewport from List.vsm RenderSettings xplode - explode 3D....vsm Enter-Exit Viewport.vsm Renumber Controls.vsm xplode - implode....vsm Escalator.vso Reset Control Tree Pathing.vsm xplode - nudge....vsm ExplodeTool Folder Reshaper 11.vsm xplode - save position....vsm Export DOE-2.vsm Resize xplode - select....vsm ./Class Line 0-5: Icon? please read me ./Common: Data ./Common/Data: 00_Arch_Sheets.mcd Notes Task Data.txt Angle-Inch.txt Notes Callout Filters.txt Tee-Inch.txt Angle-Metric.txt Notes General Filters.txt Tee-Metric.txt Channel-Inch.txt Preferences.xml UpdateResources.mcd Channel-Metric.txt Reconcile Notes.txt VA Setup Data-Metric.mcd Drawing Border Data-Arch.txt RectangularTubing-Inch.txt VA Setup Data.mcd DwgSizes.txt RectangularTubing-Metric.txt WFlange-Inch.txt IBeam-Inch.txt RoundTubing-Inch.txt WFlange-Metric.txt IBeam-Metric.txt RoundTubing-Metric.txt Wall Hatches.vss ID Prefs.txt SquareTubing-Inch.txt Wall Type Library.txt ID_Symbols.mcd SquareTubing-Metric.txt ./Common/Data/Notes: Callouts.txt General Notes.txt ./Data: ADAdata.txt DeviceLib.txt SignalTypes.txt currentversion.txt AW_Constants.vss JFdata.txt TPdata.txt ConnectorTypes.txt ReshaperKeys VDAdata.txt ./Dictionaries: AmericanEnglish.clx UserDictionary.txt ./ExplodeTool Folder: Explode.txt ./IFCEntity.vwobject: Contents ./IFCEntity.vwobject/Contents: Info.plist MacOS Resources ./IFCEntity.vwobject/Contents/MacOS: IFCEntity ./IFCEntity.vwobject/Contents/Resources: IFCEntity.qtr ./IFCExport.vwplugin: Contents ./IFCExport.vwplugin/Contents: Info.plist MacOS Resources ./IFCExport.vwplugin/Contents/MacOS: IFCExport ./IFCExport.vwplugin/Contents/Resources: IFCExport.qtr ./IFCImport.vwplugin: Contents ./IFCImport.vwplugin/Contents: Info.plist MacOS Resources ./IFCImport.vwplugin/Contents/MacOS: IFCImport ./IFCImport.vwplugin/Contents/Resources: IFCImport.qtr ./IFCLibrary.vwlibrary: Contents ./IFCLibrary.vwlibrary/Contents: Info.plist MacOS Resources ./IFCLibrary.vwlibrary/Contents/MacOS: IFCLibrary ./IFCLibrary.vwlibrary/Contents/Resources: IFCLibrary.qtr ./IFCMenu.vwplugin: Contents ./IFCMenu.vwplugin/Contents: Info.plist MacOS Resources ./IFCMenu.vwplugin/Contents/MacOS: IFCMenu ./IFCMenu.vwplugin/Contents/Resources: IFCMenu.qtr ./Includes: ./Info Editor: Bin Data Manual.pdf Read Me.rtf ./Info Editor/Bin: Info Editor.vsm ./Info Editor/Data: Door Types to Import.txt Popup Values Types.xml ./Info Editor/Data/Popup Values: Door ./Info Editor/Data/Popup Values/Door: Door Height.txt Door Width.txt ./LandruCurvedCurtain Folder: Curtain From....vsm LandruCurtain 1.0.vso ./OzCAD Preferences: WMMasterPref.txt ./Rotate Drawing v11: Icon? Merge text.vsm Install Menu command.url Rotate Drawing.url ./Space Menu.vwplugin: Contents ./Space Menu.vwplugin/Contents: Info.plist MacOS Resources ./Space Menu.vwplugin/Contents/MacOS: Space Menu ./Space Menu.vwplugin/Contents/Resources: Space Menu.qtr ./Space Tool.vwplugin: Contents ./Space Tool.vwplugin/Contents: Info.plist MacOS Resources ./Space Tool.vwplugin/Contents/MacOS: Space Tool ./Space Tool.vwplugin/Contents/Resources: Space Tool.qtr ./Space.vwobject: Contents ./Space.vwobject/Contents: Info.plist MacOS Resources ./Space.vwobject/Contents/MacOS: Space ./Space.vwobject/Contents/Resources: Space.qtr ./URLs Folder: ReadMe.txt ./VB Vector Move.vwplugin: Contents ./VB Vector Move.vwplugin/Contents: Info.plist MacOS Resources ./VB Vector Move.vwplugin/Contents/MacOS: VB Vector Move ./VB Vector Move.vwplugin/Contents/Resources: VB Vector Move.qtr ./VW_Arch: Data Interfaces ./VW_Arch/Data: AWG.txt Joist Sizes.txt Purlin Spacing.txt Beam Sizes.txt Joist Spacing.txt Rafter Sizes.txt BoltAndNut_inch.txt Lumber Sizes.txt Rafter Spacing.txt BoltAndNut_mm.txt Model To Floorplan.txt Ridge Sizes.txt Conductor.txt Plate Sizes.txt Sill Sizes.txt Conduit.txt Post Sizes.txt Sleeper Sizes.txt Dormer Rafter Sizes.txt Prefs_01 Sleeper Spacing.txt Fixtures.MCD Prefs_02 Strut Sizes.txt GSA_ABLT1.txt Prefs_03 Stud Sizes.txt GSA_SCLT1.txt Prefs_04 Trimmer Sizes.txt GSA_STBCLT1.txt Prefs_05 VA2_Preference_Set_Paths.txt GSA_SZLT1.txt Prefs_Def Wire.txt Hip Rafter Sizes.txt Purlin Sizes.txt ./VW_Arch/Data/Prefs_01: Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt Door Hdw Record.txt Plant Record.txt Wall Record.txt Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt Door Schedule.txt Rm Finish Schedule.txt Window Record.txt Equipment Record.txt Room Finish Library.txt Window Schedule.txt Equipment Schedule.txt Room Record.txt Irrigation Head.txt VA2 Records and Schedules.txt ./VW_Arch/Data/Prefs_02: Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt Door Hdw Record.txt Plant Record.txt Wall Record.txt Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt Door Schedule.txt Rm Finish Schedule.txt Window Record.txt Equipment Record.txt Room Finish Library.txt Window Schedule.txt Equipment Schedule.txt Room Record.txt Irrigation Head.txt VA2 Records and Schedules.txt ./VW_Arch/Data/Prefs_03: Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt Door Hdw Record.txt Plant Record.txt Wall Record.txt Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt Door Schedule.txt Rm Finish Schedule.txt Window Record.txt Equipment Record.txt Room Finish Library.txt Window Schedule.txt Equipment Schedule.txt Room Record.txt Irrigation Head.txt VA2 Records and Schedules.txt ./VW_Arch/Data/Prefs_04: Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt Door Hdw Record.txt Plant Record.txt Wall Record.txt Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt Door Schedule.txt Rm Finish Schedule.txt Window Record.txt Equipment Record.txt Room Finish Library.txt Window Schedule.txt Equipment Schedule.txt Room Record.txt Irrigation Head.txt VA2 Records and Schedules.txt ./VW_Arch/Data/Prefs_05: Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt Door Hdw Record.txt Plant Record.txt Wall Record.txt Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt Door Schedule.txt Rm Finish Schedule.txt Window Record.txt Equipment Record.txt Room Finish Library.txt Window Schedule.txt Equipment Schedule.txt Room Record.txt Irrigation Head.txt VA2 Records and Schedules.txt ./VW_Arch/Data/Prefs_Def: Door Hardware Library.txt Irrigation Line.txt VA_Project_Set.txt Door Hdw Record.txt Plant Record.txt Wall Record.txt Door Hdw Schedule.txt Plumbing Fixt Record.txt Wall Type Library.txt Door Record.txt Plumbing Schedule.txt Wall Type Schedule.txt Door Schedule.txt Rm Finish Schedule.txt Window Record.txt Equipment Record.txt Room Finish Library.txt Window Schedule.txt Equipment Schedule.txt Room Record.txt Irrigation Head.txt VA2 Records and Schedules.txt ./VW_Arch/Interfaces: HVAC_Duct_K.vss ./VW_Land: Interfaces ./VW_Land/Interfaces: Import Survey File_D.vss ./VW_Mech: Data Includes ./VW_Mech/Data: CapSlottedFillister-Inch.txt HexBoltStruct-Metric.txt MachOval-Inch.txt CapSlottedFlat-Inch.txt HexScrew-Inch.txt MachOval-Metric.txt CapSlottedRound-Inch.txt HexScrew-Metric.txt MachPan-Inch.txt CapSocButton-Inch.txt LockWasher-Inch.txt MachPan-Metric.txt CapSocButton-Metric.txt LockWasher-Metric.txt MachRound-Inch.txt CapSocFlat-Inch.txt MachBind-Inch.txt MachTruss-Inch.txt CapSocFlat-Metric.txt MachFill-Inch.txt Nut-Metric.txt CapSocHead-Inch.txt MachFlat-Metric.txt NutHexJam-Inch.txt CapSocHead-Metric.txt MachFlat100-Inch.txt NutRegularHex-Inch.txt HexBolt-Inch.txt MachFlat82-Inch.txt NutSlotted-Inch.txt HexBolt-Metric.txt MachHex-Inch.txt NutSquare-Inch.txt HexBoltFinished-Inch.txt MachHex-Metric.txt PlainWasher-Metric.txt HexBoltFinished-Metric.txt MachHexF-Metric.txt PlainWasher-TypeA.txt HexBoltHeavy-Inch.txt MachHexS-Inch.txt PlainWasher-TypeB.txt HexBoltHeavy-Metric.txt MachHexW-Inch.txt SquareBolt-Inch.txt HexBoltStruct-Inch.txt MachHexWS-Inch.txt ./VW_Mech/Includes: VWMechanical_K.vss ./WeightInfo Folder: Weight_info.vsm readMe.pdf specificWeightsTable.txt ./texteyedropper Folder: TextEyeDropperDocs.TXT Quote Link to comment
ErichR Posted May 13, 2008 Author Share Posted May 13, 2008 Good thing you've got nothing better to do. Quote Link to comment
islandmon Posted May 14, 2008 Share Posted May 14, 2008 last time i will ever try to help you out ... Quote Link to comment
brudgers Posted May 14, 2008 Share Posted May 14, 2008 (edited) Incidentally, the NNA people who frequent the board are probably gearing up for AIA Boston this week. Edited May 14, 2008 by brudgers Quote Link to comment
Kevin Posted May 14, 2008 Share Posted May 14, 2008 islandmon, I for one do appreciate all that you contribute to this forum. Thank you. Quote Link to comment
ErichR Posted May 14, 2008 Author Share Posted May 14, 2008 Seemed a bit unnecessary for Islandmon to list a gazillion v11.5 files, when my issue is with v12. I called VW Tech Support. After much fooling around, including a tortuous uninstall and a reinstall, it appears that their own v12.5.3 has the same problem. Possibly it's an issue with QuickTime. One wonders if any of the Windows versions of v12+ work for animation. Tech is to get back to me. Quote Link to comment
ionw Posted May 14, 2008 Share Posted May 14, 2008 ...And the process he was suggesting is so different for other versions of Vectorworks. Quote Link to comment
Tobias Posted May 14, 2008 Share Posted May 14, 2008 I agree, Islandmon is always a help, learned much from his posts, and even more when he posts a file and you can see how he sets up a VW project, very very helpful. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 15, 2008 Vectorworks, Inc Employee Share Posted May 15, 2008 (edited) Eric, Please send a private message with an email address so that we can send you these missing plug-ins. Thanks Edited May 15, 2008 by Tech Quote Link to comment
ErichR Posted May 15, 2008 Author Share Posted May 15, 2008 Tech (Alicia) solved it and emailed the missing plug-in files. V12 was supposed to have been complete, but was missing them, so the animation command was non-functional from the original v12 through v12.5.3. Case Closed. Thanks! Quote Link to comment
Kevin Posted May 15, 2008 Share Posted May 15, 2008 Thank you for the update. Glad that your situation is resolved. However, your phrasing suggests that other users should be experiencing missing plug-ins. Could you elaborate on whether this situation is isolated to your installation or, as you say, that V12 from VW is missing these plug-ins. If so, then all of us will certainly want to receive these plug-ins that are missing. Quote Link to comment
islandmon Posted May 16, 2008 Share Posted May 16, 2008 I'm back ; ) .. hey glad that the problem was resolved ... all i wanted to show was that it is easy to create a recursive listing of any path-able directory( even works via ftp, too ) . The old v11.5.1 was just an example of the process using Terminal command > ls -R , which is pretty basic and easy to do ( Win command line has somewhat similar syntax ). I apologize for the length of the attached list , but it serves to illustrate the recursive nature of the nested directory listings. This can be very helpful when there is a question regarding the existence of various plug-in & includes components not only in VW with with all applications & installs. My humble thanx to those who submitted positive support comments . Quote Link to comment
ErichR Posted May 16, 2008 Author Share Posted May 16, 2008 (edited) Kevin - Tech said that v12 did ship with the proper plug-in files, but didn't have any explanation why in their copy and mine they were absent. The v12 installation disk does have the files, they say, but updates do not. BTW, since I knew that the animation dialog box had two options in its upper pull-down, I did a search for 'path' and one for 'orbit' (in v11, which did work) in the Plug-ins folder, and came up with 4 files. This was before I called tech. I stuck those files in the V12.5.3 plug-ins folder. Voila! the animation dialog box appeared, but didn't have any functionality. Then the call to tech. Coincidentally, I was on the right track, because the 4 files tech emailed me were the same ones (but v12) I had gleaned from v11. These are the elusive files: OrbitAnimator.dll OrbitAnimator.qtr PathAnimator.dll PathAnimator.qtr Edited May 16, 2008 by ErichR Quote Link to comment
