The Cantor Posted March 6, 2008 Share Posted March 6, 2008 For all of you that end up doing corporate or other events in ballrooms and convention centers across the country, here is a source for a good number of drawings. Meeting Matrix http://www.meetingmatrix.com/ Three Issues: 1) The file generated can not be exported as a dxf or dwg. 2) Need a PC to run the MM application. 3) You have to get a free subscription to Meeting Matrix, and download the free silver version. Procedure I follow is... 1) Search the MM venue drawing library. 2) Download the venue drawing package. 3) Open the specific room, and draw a couple of dimension lines. 4) Print as a PDF file. The pdf is a vector-based file. 5) Open the PDF file in Illustrator. 6) Export from Illustrator as a DWG file. 7) Import into a new VW file. Measure the distances you have from the Meeting Matrix file dimension lines. 8) Do a simple proportion, and scale entire drawing. Make sure to confirm that your proportion was correct. 9)Open a new layer, with the MM drawing on a layer below and be in 'show snap others' mode. 10) Use the MM lines as your template. MM claims that the drawings are accurate. You could import the pdf direct to VW, but it will be like importing a picture, with no snapping capabilities. When you can't do a survey, it's a pretty good source. Good Luck... Quote Link to comment
Pancho Posted March 8, 2008 Share Posted March 8, 2008 I was hoping VW2008 would help those of us with a similar issue avoid the awkward hop in and out of Illustrator. Why can't VW parse pdf files yet?? Quote Link to comment
The Cantor Posted March 9, 2008 Author Share Posted March 9, 2008 Several months ago, our St. Louis Mo. user group did a webcast with the guy that wrote Spotlight. He mentioned that VW and Adobe would be working closer together in the near future, and that this was one of the bigger issues soon to be worked out. Just wonder how near we are. In the mean time, this path via Meeting Matrix and Illustrator offers a relatively descent room template for those of us that deal with the issue day in and day out... Quote Link to comment
