Greg_at_ils Posted January 18, 2008 Share Posted January 18, 2008 Whenever I try and use Document Setup to set a drawing border and title block preference by selecting "As preference when sheets are created" and not choosing the option to create them now on a layer, I get an error. Error: _0 _118 - Menu cannot be found. Fit to Page Area If I also select the "To create a border now on layer:" then I do not get the error but it still does not make it a preference. It creates it on the selected layer but not when new sheets are created. Quote Link to comment
Pat Stanford Posted January 18, 2008 Share Posted January 18, 2008 Are you using a custom workspace? If so, try switching to the standard (or architect or Designer) workspace prior to running the command. If that works, then you need to add the Fit to Page Area to your workspace. It is normally in the View menu. Pat Quote Link to comment
Greg_at_ils Posted January 18, 2008 Author Share Posted January 18, 2008 I already checked for that. I get the same error in any workspace plus I do have the menu item in my custom workspace. Quote Link to comment
Pat Stanford Posted January 18, 2008 Share Posted January 18, 2008 I don't have any other ideas and I get the same thing here. I would submit it as a bug if I were you. Pat Quote Link to comment
