domer1322 Posted November 15, 2007 Share Posted November 15, 2007 Using VW 2008, I opened a project I did in VW 12.5.2 about 3 months ago, and to my dismay found that many of the leader lines from the callouts were twisted (in relation to the arrowheads) and the text was rotated at odd angles.... sometimes vertical, sometimes 30 degrees from horiz, etc... Upon review, it appears that all the callouts where I used bezier line leaders were messed up. The control points for the lines are so messed up I can't even seem to manually move the control points to get them correct again. This occurs on many sheet layers and many viewports (annotations). Is this a bug, or is this unique to my project? or is there a work-around ? Using VW2008 (updated version 13.0.0 (78970(SP1)) on Windows XP Pro Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted November 15, 2007 Vectorworks, Inc Employee Share Posted November 15, 2007 domer, I have seen a host of callout problems (which are to be fixed in an upcoming maint. release) but I ahve not seen this. Could you send the malfunctioning VW12.5 file (along with a description of a way to reproduce the problem) to bugsubmit@nemetschek.net? Quote Link to comment
