How Posted November 8, 2007 Share Posted November 8, 2007 I have created a DTM by tracing contours using 3D polys, gave them all Z heights, that has worked just fine. A lot cheaper than buying 3-D data. I now need to export this as a survey file X,Y,Z in a word style format. How can I do this? Can I dictate how it is converted is terms of creating a grid of 3D locus points or dose it put one at every junction of the poly lines. Thanks Matt Quote Link to comment
Petri Posted November 8, 2007 Share Posted November 8, 2007 1. Why not use the 3D-polygons? 2a. You perhaps can, by buying expensive software for this pointless exercise. 2b. Why not place 3D loci at selected vertices and get rid of the polygons? At this juncture I may sound like Robert Anderson, but: by having a huge number of points, you are just asking for trouble. You may well have traced the result of a DTM process. If you can get the actual source data, you are much better off. Unless your hourly rate is zero. Quote Link to comment
