domer1322 Posted November 5, 2007 Share Posted November 5, 2007 one tip .... my Dell scroll wheel only works when VW 2008 is on the main monitor. If I slide the screen window to the other monitor, the mouse scroll wheel doesn't work. (Obviously, I put palettes on one monitor and drawing on the other ... the scroll wheel doesn't work in the pallets on the 'secondary' monitor.... when I slide the pallets to the main monitor, the scroll works in the pallets just fine.) Quote Link to comment
domer1322 Posted November 5, 2007 Share Posted November 5, 2007 after my last post... I got curious and went back to try something. I went into the Windows XP display control panel and the only thing I did was shift my #2 monitor from the left side of the #1 monitor, over to the right side. Now my scroll ball works equally well on all pallets and drawing windows, on both monitors. Very strange... but hopefully helpful to the VW engineers. PS : I tested the scroll wheel on the Windows explorer panels and the scroll wheel worked equally well on both monitors, for each monitor position situation. This appears to be VW 2008 related. Quote Link to comment
PJLA Posted November 5, 2007 Share Posted November 5, 2007 Dormer 1322 AS you suggested, shifted VW2008 to main monitor and the mouse scroll wheel works! Thank you Regards PJL | UK Quote Link to comment
Guest Donne Martin Posted November 5, 2007 Share Posted November 5, 2007 The mouse wheel zoom bug should be fixed in the next service pack. Thanks Donne Quote Link to comment
GlennF Posted December 5, 2007 Share Posted December 5, 2007 We are having the same problem here. moving the monitor to the right side seems to fix the problem. Thanks for the info and when can we expect a fix? Quote Link to comment
Guest Mark Farnan Posted December 6, 2007 Share Posted December 6, 2007 (edited) [entry deleted] Edited December 6, 2007 by Mark Farnan (NNA) Quote Link to comment
