Buster Posted October 14, 2007 Share Posted October 14, 2007 Hi: When i draw up and down, lines scale correct When i draw left and right, lines do not scale correctly. can anyone help? Quote Link to comment
Ray Libby Posted October 15, 2007 Share Posted October 15, 2007 Much more information needed. By left and right do you mean a horizontal line? What do you mean by scale correctly? What version VectorWorks? Quote Link to comment
Buster Posted October 15, 2007 Author Share Posted October 15, 2007 Yes i mean horizontalline. I am using version 8. Whwn I am drawing in 1/4 scale on 11 x 17 paper an i draw a 33 ft line the line scales to 24' 4" not 33' any ideas. Thanks Quote Link to comment
Ray Libby Posted October 15, 2007 Share Posted October 15, 2007 What do you mean by scales? Quote Link to comment
Buster Posted October 15, 2007 Author Share Posted October 15, 2007 The vertical lines scale to the correct measurement but the horizonal lines are shorter then what the scaled measurement says it is. Thanks Quote Link to comment
CipesDesign Posted October 15, 2007 Share Posted October 15, 2007 Version 8??? As in MIniCad 8??? Wow! Quote Link to comment
jan15 Posted October 15, 2007 Share Posted October 15, 2007 I think v8 is when they started using the name VectorWorks. The manual and disk are labelled "MiniCad VectorWorks." Buster, are you saying you drew a 33' long line on a 1/4" = 1'-0" layer, and the Object Info palette says that it's 33' long, and that it's on the 1/4" layer, not some other layer, but it printed out 6.08325" long rather than 8.25" long? And this is only happening in the X direction, not the Y direction? So drawings are printing out with a distorted shape, taller and thinner than they should be? And normally your printer doesn't distort the shape of anything? And you printed directly from VectorWorks, not to a PDF file and then to the printer? That's really weird. Is this the first time you've printed anything from VectorWorks? Have you printed before to the same printer without that problem? What's your computer's operating system? Quote Link to comment
Buster Posted October 15, 2007 Author Share Posted October 15, 2007 Hi Jan15, Yes that is correct. I have used this program for several years with no problem. I printed to a couple different printers with the same results, direct from my system and by a pdf file sent by email. I'm finding now that some of the pages scale correctly and not others. I am looking at each pages settings to see if i can determine anything, but nothing yet. I'm using windows xp, but I don't remember what version. it was installed in April 07. Thanks Quote Link to comment
Buster Posted October 15, 2007 Author Share Posted October 15, 2007 The version is xp pro 2002 Quote Link to comment
jan15 Posted October 15, 2007 Share Posted October 15, 2007 The only thing I can think of that would cause the problem is if the X-axis lines are actually on a different layer, at a different scale. You might try drawing a dimension object showing the length of the 33' line, and then post a screen shot and also a scan of the print-out with a scale lying next to the line. It seems very unlikely that it's a glitch in the software, but if all else fails you could try removing and reinstalling. They don't support version 8 on XP, but I personally used that set-up for about a year and never had any problem. I don't remember which Windows Service Pack I had, but I remember being afraid to install a later one because of rumors that it conflicted with some older applications. Quote Link to comment
Guest Posted October 15, 2007 Share Posted October 15, 2007 Are you checking "Fit to Page" or some option of the likes when printing? Can you correctly dimension the shape within VW? Are you measuring using a scale bar? Are you drawing really far away from the origin, or has the origin been moved? Can you duplicate the issue in a new, blank document? What version of VW 8 are you using? Quote Link to comment
Cris with no H Posted October 15, 2007 Share Posted October 15, 2007 Katie has almost certainly got it in her first question. Every time I've encountered the print not coming out correctly scaled in one dimension, it's been a Fit to Page issue somewhere in the print drivers. Cris Dopher Quote Link to comment
