gScott Posted October 1, 2007 Share Posted October 1, 2007 i've got a 3 storey building with 2 stairs, one stair from floor 0 to floor 1, + one stair from floor 1 to floor 2. the stairs are in different places in the building + of different layouts... i make a stair from floor 0 to floor 1, check the breaks for upper + lower floors, and all looks fine. i go to floor 1 + duplicate the stair, set it's new upper + lower floors <1 to 2> + adjust the layout. it all looks fine on floor 1, you see the top of the lower stair + the bottom of the upper stair, go to floor 2 + you see the top of the upper stair. all fine... but going to floor 0, the bottom of the lower stair has disappeared. go to floor 1, check the upper + lower levels are correct, press apply, + the bottom of the upper flight disappears, but the top of the upper flight is there on floor 2, incorrectly shown with the lower flight's dimensions... correct the upper flight + the bottom of the lower flight disappears off floor 0... etc etc... delete one flight + the other is deleted simultaneously... this is a new file, 12.5.2... any chance of this being fixed in 12.5.3, robert? Quote Link to comment
Robert Anderson Posted October 1, 2007 Share Posted October 1, 2007 Gideon, I've tried to replicate your error in my copy of 12.5.2 according to the process you've laid out, but I cannot. I'm checking to see which internal version of 12.5 I have installed on my computer. Here are my questions: -Do you have more than one version of VectorWorks 12 installed on your machine? When you choose "about VectorWorks", what build number is shown (5 digit number)? -When you say a "new file", is this an absolutely blank file, not a template? Quote Link to comment
gScott Posted October 2, 2007 Author Share Posted October 2, 2007 robert, xp sp2, only 1 installation of VW, VW 12.5.2<71041> it was a new file from a custom template, but i'll try a completely blank file in the morning. thanks Quote Link to comment
gScott Posted October 2, 2007 Author Share Posted October 2, 2007 robert, tried all of my templates today, and they all fail on the multiple stairs, as previously described.. on a 'blank' new file they work correctly. i guess this means i will have to rebuild my templates Quote Link to comment
Don@Black Dog Posted October 2, 2007 Share Posted October 2, 2007 I have also noticed in the past that copied stairs seem to be linked. I ran an experiment on an older project, copied the stairs, changed the floor layers, settings, etc. When one or the other is deleted, the other goes also (even making sure they are both de-selected to begin with). Try it in flyover and see! The cleanest way is to make new stairs in each location, though contrary to the usual benefits of CAD. Quote Link to comment
Robert Anderson Posted October 5, 2007 Share Posted October 5, 2007 Any document in which you've experienced stair linking problems needs to have the "fix stair associations" script run, and it should be OK. This is a document corruption issue. If your templates are showing the issue, it means you have to rebuild them. Quote Link to comment
