rsa Posted July 11, 2007 Share Posted July 11, 2007 When I change the class of the window schedule ID bubble in the window edit data pane it keeps reverting back to none everytime I open the window to edit its data. This is maddening since I want the window ID symbol to be on a separate class so I can turn it off, but I have to remember every time to change the class back again before closing the edit window. Is this something that can be fixed/changed?? Quote Link to comment
Jeffrey W Ouellette Posted July 11, 2007 Share Posted July 11, 2007 What version of VW are you using? Quote Link to comment
rsa Posted July 12, 2007 Author Share Posted July 12, 2007 Anyone else have this problem? Quote Link to comment
panthony Posted July 12, 2007 Share Posted July 12, 2007 Yes...this was a problem with the last version. The system reverts to the class at the top of the order whenever the setup window is invoked to change the parameters of a window or door. Sometimes it can be quite annoying. I even tried to delete the class but it gets re-created when the parameter window is invoked. pa Quote Link to comment
