Christopher Posted February 24, 2000 Share Posted February 24, 2000 Issue: I'm trying to import a Acad v.14 drawing (581K) and am persistently getting an "Out of openDWG memory. Cannot Continue" message which forces me out of Vectorworks 8.5.1. I have tried allocating 100mB (max.), 40mB, and 15,004 (min.) to Vectorworks to check the range. Same result. Any suggestions? Anyone had this before? config...beige G3/233/224ram TIA Christopher Gowing Quote Link to comment
Guest Posted March 4, 2000 Share Posted March 4, 2000 If you have access to any other software that can import DWG I would try to open the file there to make sure that the DWG file that you are using is not damaged. If you can't please contact Tech Support so can try the file for you. ------------------ Shawn Waithe Diehl Graphsoft inc. Tech Support Manager Quote Link to comment
GRC Posted March 10, 2000 Share Posted March 10, 2000 Try DXF format. Good luck. Quote Link to comment
