TBrown Posted June 1, 2007 Share Posted June 1, 2007 I like to use a different font for my dimensions. I find it helps to distinguish them on a drawing already crowded with notes etc. I currently dimension the drawing as completely as possible using the default font then do a "custom selection" and change the font globally. This is acceptable, but wondered if there was a way to set the font for a class, and if not I would certainly make this a wish list item. Quote Link to comment
Robert Anderson Posted June 1, 2007 Share Posted June 1, 2007 Use the "Custom Selection" command to select everything in the "Dimension" class. Then choose the desired font off the Text menu. Quote Link to comment
Dieter @ DWorks Posted June 2, 2007 Share Posted June 2, 2007 that's how it is done, but i agree with TBrown that this is a thing that should be attached to a class, or maybe a parameter for dimensions Quote Link to comment
