Alexander Maier Posted January 22, 2000 Share Posted January 22, 2000 After installing Mac OS 9, dragging objects several times causes the computer to freeze. Sometimes only VW crashes, sometimes it's the whole OS. I experienced this on a 9500/120 (96 Mb), on a bw G3 (256 Mb) and on a G4 (256 Mb). All of the machines worked well with OS 8.6 installed. Does anybody know a solution or experience the same problems? Quote Link to comment
Alexander Maier Posted January 24, 2000 Author Share Posted January 24, 2000 quote: Originally posted by Mark H: After installing Mac OS 9 on my machine, it reset all of the memory allotments for all of my programs. I had to go through and allocate more memory to all of my programs. Make sure you have enough memory to run the program and also to perform the tasks you are trying to do. If you allocate more memory to the program that may solve the problem. I consider the problem to be Apple-, not Diehl-related. The only solution seems to be to await 9.0.1. Reassigning more memory doesn't help a bit. Quote Link to comment
Guest Posted January 25, 2000 Share Posted January 25, 2000 After installing Mac OS 9 on my machine, it reset all of the memory allotments for all of my programs. I had to go through and allocate more memory to all of my programs. Make sure you have enough memory to run the program and also to perform the tasks you are trying to do. If you allocate more memory to the program that may solve the problem. Quote Link to comment
Maurice Clarke Posted March 28, 2000 Share Posted March 28, 2000 quote: Originally posted by Alexander Maier: After installing Mac OS 9, dragging objects several times causes the computer to freeze. Sometimes only VW crashes, sometimes it's the whole OS. I experienced this on a 9500/120 (96 Mb), on a bw G3 (256 Mb) and on a G4 (256 Mb). All of the machines worked well with OS 8.6 installed. Does anybody know a solution or experience the same problems? Quote Link to comment
Maurice Clarke Posted March 28, 2000 Share Posted March 28, 2000 quote: Originally posted by Alexander Maier: After installing Mac OS 9, dragging objects several times causes the computer to freeze. Sometimes only VW crashes, sometimes it's the whole OS. I experienced this on a 9500/120 (96 Mb), on a bw G3 (256 Mb) and on a G4 (256 Mb). All of the machines worked well with OS 8.6 installed. Does anybody know a solution or experience the same problems? I am experiencing the same problem. There appears to be no logic to when the program freezes. If anyone out there has the answer please let us know. DiehlGraphsoft please note! Quote Link to comment
MikeB Posted March 29, 2000 Share Posted March 29, 2000 I've posted my problems with freezes on a G4 w/ OS9 an stillhavent found a solution. It seem to have someting to do with screen regen becuse it happen alot when I grab an object and drag it to the side of the screen so it automatically pans. I tried turning off my vidio accleration extensions but this did not help. So I Dont Know. But on another subject Adobe has a new version of ATM for OS9 I Down loaded it and installed it and it seems to have helped with several other problems in VW(slow regen of worksheets, etc.) Quote Link to comment
Maurice Clarke Posted March 30, 2000 Share Posted March 30, 2000 quote: Originally posted by MikeB: I've posted my problems with freezes on a G4 w/ OS9 an stillhavent found a solution. It seem to have someting to do with screen regen becuse it happen alot when I grab an object and drag it to the side of the screen so it automatically pans. I tried turning off my vidio accleration extensions but this did not help. So I Dont Know. But on another subject Adobe has a new version of ATM for OS9 I Down loaded it and installed it and it seems to have helped with several other problems in VW(slow regen of worksheets, etc.) I think the freezing problem may be to do with virtual memory. Since I've turned it off the problem hasn't recurred. Quote Link to comment
MikeB Posted March 31, 2000 Share Posted March 31, 2000 I think theres something to the Virtual Memory Theory. Since I turned it off I haven't crashed while panning. I hope DiehlGraphsoft will resolve this because when I'm Rendering complex models I have to turn on my VM. Quote Link to comment
