Plant label
Socram
I'm trying to get a label to show up next to each type of plant I have in my document. like an arrow from the Common Name to the graphic of the plant. I know how to get 'tags' to show up, but they display only the ID and quantity. Is there a way to change that to Common Name & Quantity?
I've also tried using the ID label tool, but when the ID/Specification Tool window comes up, the ID Type is limited to Equipment Record, Window Object or Door Object (no Plant Record option).
Any ideas as to what I'm doing wrong?
Yes if using VWL 12.5.
Click the Settings Button up the top, Set Default Plant Tool Options/Edit Current/Tag Type and from there you can choose from lots of options. One is Qty-Common-Name - check out the others
