Refresh Instruments
So, why is it that sometimes when I select "refresh instruments" it takes 30-60 seconds and actually refreshes everything, and other times it takes 2 and doesn't refresh anything? Usually I can try exporting/importing to/from LW to try to fool VW into doing the real refresh, but no dice this time. Any thoughts?
Zenmasterj,
When I'm working in version 11, I discovered that all lighting instruments in VW need to be deselected after a LW import. Otherwise, all that gets refreshed are the units or unit that is currently selected in VW. I presume that this is also the case when not doing an import - just deselect everything before you refresh.
  • 4 weeks later...
