Plant Tags Solid Black
Matt D
Or the default fill is set to a black color with black pen.
Select the plant and take a look at the Attribute palette. If the color is set to black and black for the pen and fill, change the fill to white.
If the Attributes have an arrow pointing to the upper right, then adjust the plant tags class - I think it's called Plant Specs.
If you are working on a black background, you may need to toggle the " No Fill Behind Text" VectorWorks Preference (under the Tools>Options menu)
