Worksheet Help - PIOs
You can convert the truss into a symbol. The truss will be converted by default into a symbol when you convert the truss to a lighting position, it will just be named the same as the lighting position.
When you run the worksheet reports just choose "in object".
The other option is to add a line to look for length of the truss.
In a database row
=('Straight Truss'.LineLength)/12
Kevin
Thanks for the help!
I tried working with this for a while, and I couldn't quite get it;
If I set the criteria to count type=symbol, and I convert the truss to a symbol (position object), I do get the the name of the truss, but the length string just reads 0.
How ever, if I set the critereia to type=PIO, I get the truss length but not the name...
I'm closer, just not there yet.
