carch Posted July 24, 2006 Share Posted July 24, 2006 When batch printing I can only get one drawing to print. I put a check in front of the appropriate sheets and only 1 will print. It is usually the first one on the list. I'm using VW 12 on OSX. Any thoughts? Chris Quote Link to comment
Kevin Posted July 24, 2006 Share Posted July 24, 2006 I have given up on using batch print to print to a paper printer. I stopped because of the very problem that you describe. I use batch print to print to PDF. I still have to name each sheet when the save dialog box comes up. Quote Link to comment
cbaarch Posted July 25, 2006 Share Posted July 25, 2006 are the sheet that you are trying to print all set up to print to the same printer and all the settings all the same? the sheet settings is used after the first page Quote Link to comment
Guest Posted July 25, 2006 Share Posted July 25, 2006 What printer are you using? How much built in memory does it have? What version of OS 10 are you using? Quote Link to comment
Michael_Eschenbach Posted July 26, 2006 Share Posted July 26, 2006 for the record, I have been using Batch Print with a Designjet 500 and a Designjet 130nr without problems to date, 2 meg memory, VW12.0.1, G5 dual, although it did flake the other day when I tried to print a 26 meg file.... by the way.... if you have imported .jpg files on the drawing, and you have designated it with a 'no fill' instead of a 'solid fill' from the 'Attributes Palatte', then the file size will quadruple or quintuple. Quote Link to comment
