Ken Posted July 19, 2006 Share Posted July 19, 2006 How can I "join" a clerestory wall to the wall below? Quote Link to comment
CipesDesign Posted July 19, 2006 Share Posted July 19, 2006 You can do a join but only if the walls are on the same layer. The last time I ran into this problem I think (if I remember correctly) that I ended up using two different walls: one in the plan layer to make the join and an exact duplicate in the roof layer to be viewed in the roof plan. Each of these walls was assigned to its very class as well, so that I could make the first one invisible in the floor plan but visible in the elevations. The other option might be creating a very thin extrude in the roof layer to cover the butt end of the perpendicular wall. This is a tricky problem, therefore you need to find a tricky solution. Hopefully with these hints you'll come up with something elegant :-) Quote Link to comment
Ken Posted July 19, 2006 Author Share Posted July 19, 2006 You can do a join but only if the walls are on the same layer... Please explain how! Assume they are on the same layer. Pete, were you describing a "work around" with questionable side effects? I don't think the Join tool will work on it. The lower wall is one wall object with peaks stretched such that in side view it's an "L." It must remain as one wall. Is that the wall that you're proposing to break up? That would be quite an unwanted "side effect." Quote Link to comment
panthony Posted July 19, 2006 Share Posted July 19, 2006 Arch.Ken Is this what you are trying to accomplish Quote Link to comment
Ken Posted July 19, 2006 Author Share Posted July 19, 2006 Is that just a diagonally trimmed wall that's placed onto the lower wall? The seam still shows in orthogonal side view with hidden line render. Quote Link to comment
panthony Posted July 19, 2006 Share Posted July 19, 2006 The upper wall is actually two walls. I started from the right using the left outside line of the wall then came over the top of my lower wall and set a point...then continued up in the "+y' direction the thickness of the wall. This gives me a total exterior finish wrap on the upper celestory wall and joins the seams to the lowerwall for hidden line and also rederworks. I turned the end caps on the walls to clarify. I hope this helps Pete Anthony Quote Link to comment
Ken Posted July 19, 2006 Author Share Posted July 19, 2006 Pete, I was NOT able to duplicate your success... I created the extra wall leg: In front view hidden line render they look clean: Then I dragged them into position over the lower L wall: In isometric hidden line render they look okay: But back in front view hidden line render, the seam still shows: And the extra wall leg is not very clean for exporting: Even if the extra wall leg works as a "cover" it's very tedious, time consuming, and silly at best. I hope you're talking about something else. Quote Link to comment
panthony Posted July 19, 2006 Share Posted July 19, 2006 I've tried to duplicate the visible seam and cannot reproduce the condition. Does it have anything to do with transparency of the walls surfaces. Does this condition show in normal perpendicular wall joins. Stumped Quote Link to comment
