andrewbirch Posted May 18, 2006 Share Posted May 18, 2006 Hello everyone. I have been trying to decifer Gobo Projection in Vectorworks to no level of success. I figure this is a Renderworks topic, because you need it to do gobo projection. Is there a special library somewhere with Projector Instruments in it ? The manual references how to insert a lighting instrument, but no manufacturers symbols seem to have the Gobo1 and Gobo 2 dialogs anywhere. I am drawing a blank here. I used to know how to do this, but that was a while back, and I have forgotten. Any help would be appreciated. Quote Link to comment
Jim_Allen Posted May 18, 2006 Share Posted May 18, 2006 Andrew, You can go to the edit instrument window and you can select gobos, fog,and set a focus point for the instrument. Be sure to check turn light on. Also I had problems because I forgot to set a Z height for the unit and had the unit on the floor!!! You can also set intensity and color in that same window. Jim Quote Link to comment
andrewbirch Posted May 18, 2006 Author Share Posted May 18, 2006 Jim, Thanks. Your reply made me think to make the symbol active first, and then insert it. I was simply dragging the symbol into the drawing, and that doesn't give you all the options in the Object Info palette that the Spotlight Insertion Tool does. its the little things..... ; ) thanks. Quote Link to comment
Jim_Allen Posted May 19, 2006 Share Posted May 19, 2006 Yea - and it seems there are thousands. Check out my thread on Rendering :-( Jim Quote Link to comment
