panthony Posted May 17, 2006 Share Posted May 17, 2006 Typically Joists and Rafters are purchased in specific sizes such as 8', 10', 12', 14', 16' and so on with the shortest length being 8' and the longest dependent on availability of the material. When you frame a floor you may have pieces that are smaller than 8' which than must be added up to equal a purchased size. That being the case you would start minimizing your choices with the smaller pieces to a base minimum size of 1' which is divisible into all of the purchased sizes. If you begin to add up all the pieces which were smaller than 1' you could come up with say a 16' purchased quantity. This will make sense when you have several pieces at say 4'-9" which will round to 5' and when added up will pull from 10' purchased stock. The file which holds the standard lengths and pull stock needs to be available for modification so the user may adapt availability for specific location. VW can sum up the base sized pieces and worksheet formulas can calculate and sort to optimize the purchased quantities. Here is how it optimizes...5' pieces add to 10' purchased lengths, 2' pieces add to 4' which add to 8' which add to 16' purchased lengths, 3' pieces add to 6' which add to 12' purchased lengths, 7' pieces add to 14' purchased lengths. All of this can be accomplished with very simple math calculations in VW Response and action would be appreciated. Could someone let me know how to look into the VW script files and verify the math calcs. Quote Link to comment
islandmon Posted May 17, 2006 Share Posted May 17, 2006 Please, search the posts. Recently,I posted an example of the simple worksheet calcs for applying typ. rounding functions to quantity. Quote Link to comment
panthony Posted May 17, 2006 Author Share Posted May 17, 2006 Thanks for the input.... One thing VW needs to do is add 1', 3', 5' and 7'lengths to its script file so the system will pull 10', 12', and 14' purchased lengths at the graphic creation level. The sorting is simple once you determine what has been counted from the objects. Does VW allow manipulation of there locked scripts. I could get in there and write the code to correct the missing pieces. Quote Link to comment
