focuseddesign
imported jpgs not printing
Hello All...
Any thoughts? When printing out a fairly simple drawing in 2D plan the bmp image that I imported prints simply as the 2 intersecting lines reminiscent of the "move page" cursor. The symbols all print fine.
Machine is P4/2.0; 512 RDram; XP; HP Designjet 100.
Any tips would be appreciated.
Glenn
5 answers to this question
Did you check "Enable special processing for transparent color bitmaps" in the Print window?
Also, I remember a time when a bitmap image wouldn't print unless the whole image was within the print border. That is, I couldn't print just part of the image. But I'm not sure that's still true or was ever more than a misunderstanding of mine.
I did try that option to no avail.
I was able to print the correct page from my laptop which is a much slower machine with less memory. I didn't do anything but open the file and print it out. There must be another option I have turned on (or off) some where.
What driver do you have installed for the 100 on the computer that isn't working?
5.35 is the latest driver version available at hp.com.
You should update to this driver to alleviate the problem.
