sginder
VW10, hp 1055cm print color lines as B/W
just upgraded from OS9 to OSX and VW 8.5.2 to VW 10.1.2. and have encountered the following problem in the print window. There is no option to set the color lines to print B/W. obviously I can do this by changing the VW preferences and document preferences but why do the extra steps if it was not required in older versions. I have heard there may be 3rd party drivers that can do this. any suggestions.
Thanks
1 answer to this question
That's not a VW setting, but rather a printer setting defined by the print driver.
I'm sure if you go to other programs in OS 10 that print native in OS 10, you'll probably find the same results.
